Alternative to Garrett turbo maybe????
Old May 11, 2007 | 12:14 AM
chuntington101's Avatar
take a look at this link. very intresting stuff.
http://www.ls1tech.com/forums/showthread.php?t=707444
if they could do a BB core then you could run a 74mm and make the same power as a GT42!!
thanks Chris.
Old May 11, 2007 | 06:57 AM
EvolutionBoy67's Avatar
very interesting link. Id like to here from some of the tuners and their thoughts on these turbos.
Old May 11, 2007 | 08:17 AM
i agree EvolutionBoy67.
it seems like a great idea to me! if a ST70 can do the same as a GT42 its going to be pretty insane!
come on buschur, ams or anyone else. lets have your opinions.
Chris.
Old May 11, 2007 | 08:56 AM
Hey chuntingtion 101 do you know how big the wheel is in a gt42r? For example a gt35r is a 65lb/min wheel. How big is a gt42r?
Old May 14, 2007 | 12:17 AM
Evolutionboy im not sure mate. i think its rated at about 1000bhp but it depends what exhaust housing you get. there is a T4 and a T6 version. i think the T4 GT42 is conpearable to a T76 but im not sure.
by the way thanks for showing some intrest in this thread. seams like no one else is bothered about getting a turbo thats is smaller in size yet can diliver more power!
Chris.
Old May 15, 2007 | 05:09 AM
bump
Old May 15, 2007 | 09:58 AM
mudduck's Avatar
I'm also interested in spooling a larger turbo sooner, but was thinking on a little smaller scale than you are. I'm looking for better spool-up and powerband, not quite ready to make GT42r power. Not looking to build my engine yet...
Besides dual BB, (and more displacement or nitrous) any other ways to spool one of these bigger turbos up sooner? I know Borg-Warner uses the ET, but not sure how effective that is... Also, what about using Ti or Mg turbine components for quicker spool? Or will that result in surge?
I seriously need to talk to Robert over at FP; he really knows his sh*t...
Old May 15, 2007 | 10:14 AM
Noogles's Avatar
The ST-74 being offered by ForcedInductions is the same size Internally as a 42r 74.2mm. However they are NOT BB and will barely Spool on a 2.0 or 2.3. The Physical Size comes from Garret using a large Frame housing for the 42r's
If yo are looking for alternatives talk to Jose or DR. Turbo abou the Airwerks S200 and S300 line of turbos.
These Turbos are ment for moderately sized 6cyl and 8cyl motors that need a a bit more power without going to t6 or large frame turbos
ETT Wheels are in my opinion the Best techology to date for turbo's much better than BB CHRA's
TI Turbine wheels will kill spool! Ti is far to dense for a DD application, thats the reason Ti exhaust is so light, you can use an incredibly thin wall pipe and still keep the strength and durability . But if you plan on building a full race motor running alcohol and antilag and need a wheel to take the abuse then yes a Ti turbine wheel is for you.
Old May 15, 2007 | 11:57 PM
thanks again guys.
Noogles i think mudducl was refering to the TME turbo as that uses a Ti wheel and shaft. these things are designed for grope N use where they see alot of anti-lag and hard use and quick spool is the key. they where deisgned as a Ti turbo out the box i thnk so they use much less Ti and thus get the weight down. a bit like the Ti exhaust Noogles mentioned.
wonder if they could combined the ETT wheels with BB cores????
form what i have seen mudduck, anti-lag is the best way to reduce spool up times on an Evo. but this also reduces the life of the turbo.
Chris.
Old May 16, 2007 | 07:56 AM
Noogles's Avatar
To my Knowledge no, they will not be combining the ETT wheels until BW/AW makes their own design.
The TI wheels on the TME turbo's ar TIAl if i remember correctly just enough Ti for the density and stregth and Aluminum for weight. they are not Straigh Ti like the wheels sold by FI
Old May 16, 2007 | 08:52 AM
Noogles you are a wealth of information. hands down to you.
thanks Chris.
Old May 24, 2007 | 05:26 AM
alright Noogles, or anyone else. i have found an Evi running a T88!!!! im guessing it will be a T4 version.
see the very top of here.
http://www.lancerregister.com/mlr_modified.php#/
now it is a race setup, but still proves that BIG TRUBOS can work!
Chris.
Evolution2003
Future Lancer / Evo Models
39
Jan 15, 2016 08:12 AM
kindaloweredlif
Jul 26, 2015 08:34 PM
gkswhdl88
86
Apr 7, 2015 04:36 PM
Vapor
27
May 18, 2014 06:46 AM
