Help, just had a brain fart
Old May 11, 2007 | 03:03 PM
Apex Racer's Avatar
Quick question. I am experiencing flutter from my diverter valve between shifts and when I get off the throttle quick. It is the greddy rs recirculated. My question is should I tighten the adjustment screw or loosten it? Any help would be awsome.
And before somone says it, I have an aftermarket bov because the stock POS plastic one was not holding boost and I got the greddy used from a member for cheap.
Thanks
Old May 11, 2007 | 03:06 PM
sonicnofadz's Avatar
Why not just try it both ways and see what happens?
Old May 11, 2007 | 03:08 PM
Apex Racer's Avatar
I am probably gonna have to do that, I was just hoping somone would have the easy answer.
Old May 11, 2007 | 03:14 PM
hksevoix's Avatar
loosen it
Old May 11, 2007 | 08:19 PM
Apex Racer's Avatar
Alright, I loostened it and I dont Know if it has got better or not. It is set recirculating but it is acting like a VTA. Under low boost it will vent and then the Idle will drop significantly and almost kill the car. Any suggestions?
Old May 12, 2007 | 03:20 PM
Apex Racer's Avatar
Alright, problem solved. I took the BOV apart and removed the smaller spring from the middle. Then I reassembled it, and turned the adjustment screw by hand till it came into contact with the spring perch. Once it hit I turned it with an allen key six full turns then reinstalled it. Works perfect now. No flutter what so ever.
Thank you EVO Moto.
PcK EvO
Oct 13, 2006 01:36 PM
Quasi
Aug 2, 2006 02:13 PM
Go_Lancer_Go
Lancer Aftermarket Forced Induction Tech
Sep 12, 2005 04:42 PM
evodrifter
Jan 10, 2005 02:06 AM
mahunc
15
Aug 22, 2004 07:42 AM
