Help! Boost Gauge Install Question.
Old Aug 19, 2004 | 07:40 AM
mahunc's Avatar
I am in the process of installing a Greddy electronic boost gauge in my evo and have a couple of quick questions. There are four wires (black, white, orange and red) coming from the gauge's wiring harness that need to be tapped into the car's wiring and I am wondering where you guys tapped into (fuse panel, ecu wiring harness, etc). What are the orange and red wires for? Please help. Thanks in advance for your help.
mahunc
Old Aug 19, 2004 | 07:45 AM
nastea's Avatar
do you have a manual for it?
Old Aug 19, 2004 | 07:51 AM
Hooligan317's Avatar
The manual tells you what each wire is for, I can't remember off the top of my head what each one was. As for the wiring, you can get at it all from under the driver's side dash.
Old Aug 19, 2004 | 07:56 AM
mahunc's Avatar
I have the manual and it says what the wires are, but my real question is where to tap them into. Should i tap into the fuse panel? If so, I am not exactly sure how to do that. Or should I tap them into the factory wiring harness like I did for my turbo timer? Thanks in advance for your help.
mahunc
Old Aug 19, 2004 | 09:33 AM
mahunc's Avatar
bump
Old Aug 19, 2004 | 09:43 AM
donutmonkey's Avatar
I don't know what wire goes to what but for 12V power get one of these little chingaderas from your local parts house. They work great.
http://www.partsexpress.com/pe/showd...number=071-580
Use blank cabin fuse box circuit number 10. It supplies switched 12V. Turns on and off with the key. Use the add-a-circuit for positive, and run the ground to chassis. Just remember to put two fuses in the add-a-circuit, or it won't make a circuit. If you pull out the little change drawer there's a diagram and a set of fuse pliers.
Old Aug 19, 2004 | 10:18 AM
vr430's Avatar
I tapped all the power into and around the cigarette lighter. Check out instructions for shifter bushings installation, it tells you how to take apart the armrest/console. It's fairly easy. I routed sensor wire through the grommet in the firewall under the glove box. Have fun...
Old Aug 19, 2004 | 10:31 AM
mahunc's Avatar
Thanks for the help guys!
Old Aug 19, 2004 | 10:32 AM
are you mounting this on the A pillar?
Old Aug 19, 2004 | 10:46 AM
mahunc's Avatar
I am mounting it on the steering column. As a result the harness supplied may not be long enough to reach the cigarette lighter wiring. The harness is only about 18" long. The manual identifies the four wires as the following:
Red Wire = 12 v Power: cigarette lighter or ?
Orange Wire = Ignition Line: ?
White Wire = Parking Light Line: ?
Black Wire = Ground Line: chassis
Where can I find a supply for the ignition and parking light lines? Directly from the fuse panel? How do I connect the harness wires to the fuse panel (w/o using the little adapter thing donutmonkey mentioned - parts store near me does not have them)?
I figured it's better to ask a lot of dumb questions than to screw something up.
Thanks (again) in advance guys.
mahunc
Old Aug 19, 2004 | 11:03 AM
mahunc's Avatar
bump
Old Aug 19, 2004 | 12:25 PM
Ev0 1's Avatar
I did the same thing and it works fine.
Old Aug 19, 2004 | 12:32 PM
naucrx's Avatar
I used the instructions for the EVOM Project EVO found at this link when I installed my GReddy Boost gauge:
https://www.evolutionm.net/features/...rojectevo/24/3
Defi Wire..........................................Stoc k Wire
Constant Power (Red).....».......Black w/ Red Stripe on Radio Harness
Ground (Black).................».......Black Wire from Cigarette Lighter
Ignition On (Orange).......».......Red Wire from Cigarette Lighter
Illumination (White).........».......Green w/ White Stripe Wire from Cigarette Lighter
Old Aug 19, 2004 | 01:04 PM
plokivos's Avatar
use the dimmer wires. tap into the green wire. it's easy and if you open the bottom part of the dash, there should be a little screw on the left side for all your grounding needs.
Old Aug 21, 2004 | 08:54 AM
Buzzard's Avatar
Here's another option of where to tap into, I know the how-to is for the control unit but I'm going to post the link as an FYI. The dimmer is probably the best and easiest location to tap for a steering wheel mounted guage.
Defi Install
