HELP! Turbosmart EBoost 2
Old May 11, 2007 | 03:51 PM
JordanS4's Avatar
I recently installed my turbo smart eboost 2. I have port 3 hooked up to the compressor, port 2 on the WG, and port 1 venting out. I did not hook up any of the RPM functions, just the boost solenoid and the actual TS unit. It won't boost any higher than 18 psi, no matter I do with boost, WG, or sensitivity settings. I correctly programmed the overboost function. I don't have any visible leaks or bad connections. What am I doing wrong?
Thanks
Old May 11, 2007 | 04:14 PM
JordanS4's Avatar
should I unplug the stock BCS?
Old May 11, 2007 | 05:05 PM
nothere's Avatar
the stock unit is pretty well castrated if it doesn't connect to anything.
right at the moment I am having a senior moment and can't recall the directions, but if you follow them you should be good.
there are a number of gates you need to go through to get the boost where you want with the eboost 2, just follow the directions to the tee.
Old May 11, 2007 | 05:09 PM
04WWRS's Avatar
Jordan, there is a shop in Baltimore called Agile Automotive. Give them a call and ask for Hill. They use these alot. I'm sure he can help you out.
Old May 11, 2007 | 08:32 PM
JordanS4's Avatar
Thanks Joe, called them earlier today and they never returned my call. Ill call back tomorrow. I completely unplugged the stock BCS and added a restrictor pill from the compressor side and im boosting 21 but no more.
Old May 13, 2007 | 10:56 AM
JordanS4's Avatar
bump for help!
Old May 13, 2007 | 02:27 PM
nothere's Avatar
ok Jordan what are your settings and what turbo do you have?
sensitivty, WG , boost number, and whatever else you got.
Old May 13, 2007 | 05:35 PM
JordanS4's Avatar
I have the WG at 16 psi on stock turbo and actuator, I also have my boost and sensitivity at 70 and 70 respectively, but I've varied them both in a number of ways all the way up to 99 and 99.
Old May 13, 2007 | 06:15 PM
nothere's Avatar
try a gate pressure of 1.0 sensitivity of 17 and a 67 or so the range.
these numbers work for a WR turbo, a not to different turbo, but should get you in the right ballpark.
if you lost your instructions you can download them.
Old May 14, 2007 | 09:54 AM
JordanS4's Avatar
Wouldn't keeping the wastegate closed as long as possible be better than opening it at 1 psi? I'll try these settings in an hour and get back to you.
Old May 14, 2007 | 02:40 PM
JordanS4's Avatar
The WG @ 1, Sn at 17 and boost pres at 67 didn't make a difference.
Old May 14, 2007 | 05:44 PM
JordanS4's Avatar
Ran the line off the DV not the Compressor Housing and it works now!
Old May 14, 2007 | 07:10 PM
nothere's Avatar
its an awesome controller, glad you have it figured out now.
after you get it dialed in post what your settings are.
THmotorsports
Vendor Classifieds
454
Mar 24, 2013 06:31 PM
HyboostN
15
Jul 7, 2010 07:20 PM
THmotorsports
EvoX 'For Sale' Electronics / Lighting / Audio
21
Feb 8, 2010 04:14 PM
powerls
Jul 16, 2004 12:37 PM
agileauto.com
36
May 12, 2004 08:31 AM
