EVC problem
Old Jun 10, 2007 | 04:29 AM
tephra's Avatar
just unplug your scramble harness and see if that makes a difference...
Old Jun 10, 2007 | 04:03 PM
SupraGodTT's Avatar
ok thats the blue and the white wire plug correct?? (two wire plug) .. when I do that the beeping stops, but arent they needed to determine when and how much boost to kick in?
Old Jun 10, 2007 | 07:34 PM
tephra's Avatar
scramble is like give me 5psi extra boost for the next 3 seconds...
I dont worry about it
I am guessing you have the wrong kind of switch hooked up to it!!!
either get the right switch or just leave it disconnected...
Old Jun 11, 2007 | 01:21 PM
SupraGodTT's Avatar
Im going out in the garage to tune my Map Ecu 2 now so Ill take some pics of what I have installed, and post them so we are both on the same page here ..
Old Jun 11, 2007 | 01:59 PM
SupraGodTT's Avatar
OK wow .. I guess when I first installed it i thought the 2 pin connector ( scramble harness ) was the speed and TPS signal wires .. uh NOPE !! .. thats probably the reason it keeps beeping .. I guess I just figured that they should be their own connector and the scramble would be the ones that clipped in .. either way I have to re-connect the correct wires and ill let you know where im at after that...
Thanks for the help thus far,
Mike
Old Jun 11, 2007 | 05:11 PM
tephra's Avatar
well theres your problem
Old Jun 11, 2007 | 06:52 PM
SupraGodTT's Avatar
ALRIGHT Well now I have to hook the vacuum lines back up and take her out for a spin tomorrow .. time permitting .. and i'll let you know how I make out ..
Thanks again,
Mike
Old Jun 11, 2007 | 07:16 PM
tephra's Avatar
COOL - just be careful with bringing on full boost.
set your warning level to 21psi or something so you can hear it beeping if it goes over that...
Old Jun 21, 2007 | 12:21 PM
SupraGodTT's Avatar
For some reason its not reading boost/vacuum whatsoever .. it will tell me my TPS% but NEVER boost.. HMM ..
here is how I have it hooked up ..
Single Turbo with an external wastegate .. the "On the turbo" connection is just that, the connector is on the turbo itself not the intake ..
Old Jun 21, 2007 | 05:31 PM
tephra's Avatar
check you have the intake manifold connection done properly... no kinks etc etc...
Old Jun 21, 2007 | 06:18 PM
SupraGodTT's Avatar
yeah i ran it nice and neatly along the firewall and behind the hardlines ..
Old Jun 21, 2007 | 06:38 PM
tephra's Avatar
so when you start the car you don't get -10PSI ish?
Old Jun 22, 2007 | 05:21 AM
SupraGodTT's Avatar
I get nothing what soever .. just 0.0 .. i was kinda surprised at that as well ..
Old Jun 22, 2007 | 06:51 AM
tephra's Avatar
hrmm double check your lines again
what have you tapped into @ the manifold?
Old Jun 22, 2007 | 07:43 AM
SupraGodTT's Avatar
there are 2 nozzles if you will on the back of the intake mani.
the top is for just the boost controller
the other is for fuel press. reg. , a boost gauge and a vac. source for my MAP ECU 2
