Best Clutch.... For about 600 whp.
Old May 15, 2007 | 09:29 AM
PedroMartinez's Avatar
Whats the best clutch not so expensive but not cheap. like the BEST clutch for about 600 whp. I have searched but couldnt find anything....
Old May 15, 2007 | 09:40 AM
deadbeatrec's Avatar
exedy heavy twin
https://secure.buschurracing.com/cat...0267c254b9083e
Old May 15, 2007 | 09:43 AM
pjsevo8's Avatar
I use the Tilton Twin at those power levels. I would agree that the exedy triple is easier to drive so I would have to say that as well.
Old May 15, 2007 | 09:44 AM
TeStUdO's Avatar
I would say at the 600hp point you are in triple carbon territory.
pjsevo8's Avatar
I've seen a bunch of exedy twin HD's go at 550whp on a mustang.
Originally Posted by deadbeatrec
Old May 15, 2007 | 09:48 AM
AlohaEvo's Avatar
I have the tilton carbon/carbon on my DD and it drives fine, just have to get used to it
Old May 15, 2007 | 09:50 AM
TeStUdO's Avatar
I would personally rather have a little overkill when it comes to the clutch since it is such an expensive part that wears out.
I rock the Twin Disk HD right now and it is great.
If I ran 600 hp I would run a triple disk, especially if I tracked the car heavily.
Old May 15, 2007 | 09:51 AM
pjsevo8's Avatar
Dont get me wrong I love the way my tilton engages but I could see some ppl not liking it. The pull spring of the exedy as opposed to our hydraulic makes the exedy a little easier to drive... IMO anyways
PJ
Old May 15, 2007 | 12:28 PM
Jean's Avatar
Tilton
Old May 15, 2007 | 12:52 PM
richie11's Avatar
If u want a street-able clutch to hold 600 whp, then look no further than the cusco twin plate clutch, most people tell me it is the same as the exedy twin plate, but i find the cusco has less chatter and easier to slip
Heres a Link
http://www.z1auto.com/prodmore.asp?model=evo&cat=driveline&prodid=363
Old May 15, 2007 | 12:55 PM
Nez136's Avatar
I think your clutch selection is going to be based on the TQ your machine will put down....since that is how clutch strength is messured. A lot of these 600whp machines are only putting down 450-500 ft lbs to the wheels. An Exedy twin would be fine for that (depending on whos dyno your talking about)
Old May 15, 2007 | 12:59 PM
pjsevo8's Avatar
IA performance here in town has had two evo's with exedy twin hd's go out one putting down close to 450 ft/lbs and one doing 504 ft/lbs. You would need to go with an exedy tripple to be safe...
PJ
Old May 15, 2007 | 09:16 PM
PJ
where can i find the exedy triple one?
also why is exedy so expensive?
Old May 15, 2007 | 10:47 PM
8URVTEC's Avatar
I had the Cusco Twin and did not hold past 500 ft/lbs! I had to build up to a triple and that is doing very well. The Cusco was built up using three Exedy clutch disks and two Exedy intermediate plates, the pressure plate and flywheel were reused. Thanks IA Performance!!!!!!
Old May 15, 2007 | 11:33 PM
Top_End_EVO's Avatar
Tilton Twin Cerametallic! Not too Cheap ($600 single disk that will slip) and not too expensive ($2400 for a carbon clutch)
Like the one I pmed you about!
