Best forge pistons for IX with stock ECU?
Old May 16, 2007 | 02:07 PM
hevolution81's Avatar
that is funny because I know that both the sti and mazdaspeed3 have forged rods and week pistons, so the evo is backwards or maybe they are?.
Old May 16, 2007 | 03:25 PM
94AWDcoupe's Avatar
the evo8 and 9 pistons are NOT forged. they are definately cast. dont believe some stupid article. the factory pistons run .0015 pistons to wall clearance. no way on earth can you run that clearance on forged pistons. they swell way to much under boost.
Old May 16, 2007 | 03:28 PM
hondafan's Avatar
well, they're pretty stout for cast then! i wish we knew the true answer.
Old May 16, 2007 | 03:29 PM
Chris@nolimitmotors's Avatar
i really didnt think they were either.
Old May 16, 2007 | 03:37 PM
Silk's Avatar
The cranks forged
Old May 16, 2007 | 06:26 PM
DG Motors's Avatar
dont worry about pistons on the green.....you should be fine
Old May 16, 2007 | 06:48 PM
Exciting News's Avatar
They sure looked cast when I was looking at a set. They looked downright feeble when compared to a forged aftermarket set.
Old May 16, 2007 | 06:55 PM
freddiet's Avatar
where the hell has this post gone man get back on the subject!
Old May 16, 2007 | 06:59 PM
SeanC's Avatar
Originally Posted by hondafan
well, they're by no means as beefy in the ring land area as aftermarket forged pistons, but good enough to hold 19psi of boost stock and get a 100K mile warranty with. plus, lots of guys run around 500hp with the stockers reliably.
The OEM pistons are designed to be....OEM pistons! In other words, they must be quiet, inexpensive to manufacture, efficient, and of hold up to whatever a standard engine (and then some) can throw at it. A cast OEM piston can be heat treated and made extremely hard. This may make the piston look strong by numbers, but also very hard and non-ductile. You should have no problems as long as your tuning is good. A little detonation and that hard piston can fail, usually on the second ring land or crown.
If you have any doubts, just upgrade.
Old May 16, 2007 | 08:58 PM
urslo4n8's Avatar
IS the crank forged? Seems like all the articles are gettin it wrong
Old May 16, 2007 | 11:45 PM
evospec's Avatar
Is 0.0025" piston to wall clearance enough for a forged pistons?
What is the forged piston (example, wiseco) recommended spec for piston to wall clearance before getting excessive piston slap and premature wear?
Old May 17, 2007 | 02:46 AM
Oracle1's Avatar
Anyone got any experience with JE pistons or wiesco? Does it interfere with the stock knock control system?
Old May 17, 2007 | 03:25 AM
Evo_7's Avatar
Originally Posted by Bosshog
I second that. my tuner says the stock pistons are fine upto around 500hp.
consevatively, he recommends to upgrade stock rods for 500hp (mainly bigger turbos than 20G variants such as hks 3037) and fully forged engine after that. yes you can put a larger turbo on stock internals, but what is the point of babying it after installing a larger turbo and loosing a ton of spool
the more I ride in stroked big tubo cars, the more I like the car on the stock turbo - with that much power, the car becomes a straight line car unless you are very talented driver with brass *****
Its the Rods which cause the failure...and they are not good up to 500.....
Anything above 450+ its your luck thats keep it....
And as soon as it runs out BOOM!
Old May 17, 2007 | 03:29 AM
Evo_7's Avatar
As for the stock pistons i think they are forged...
And if you really want to compare then compare stock rods with any other aftermarket rods...
Old May 17, 2007 | 03:44 AM
Bosshog's Avatar
I said that stock pistons are fine upto around 500hp.
I also suggested to upgrade stock rods for 500hp (mainly bigger turbos than 20G variants such as hks 3037)
I agree on 450+ 20G turbos basically make upto 460hp on a safe pump tune and anything bigger would be better with upgraded rods...
