reving to 8k safely
Old May 17, 2007 | 07:57 AM
fastassfourdoor's Avatar
reving to 8k safely
would upgraded piston and rods be enough to rev a 35 r to 8k for a daily driver...............or what exacley have some of you guys done.
Old May 17, 2007 | 08:42 AM
Ludikraut's Avatar
Upgrade your valvetrain first.
l8r)
Old May 17, 2007 | 08:46 AM
scorke's Avatar
Don't need anything to rev to 8k besides a reflash.
Scorke
Old May 17, 2007 | 08:47 AM
Gary 805's Avatar
I ride to 8k with a reflash.
Old May 17, 2007 | 08:48 AM
WrX Kila's Avatar
Old May 17, 2007 | 09:49 AM
Noogles's Avatar
Taken my stock bottom end, stock valve spring car to 8500 rpm lots of times to keep the 37r in it's optimal RPM range during races. I would recommend, but the engine can handle it.
Old May 17, 2007 | 10:11 AM
scorke's Avatar
What noogles meant to say is he wouldnt reccomend it, but his particular engine has handled it fine
Scorke
Old May 17, 2007 | 10:23 AM
EvoDan2004's Avatar
Don't u think adding arp rod bolts would add some insureance when reving to 8k on stock block???
Old May 17, 2007 | 10:25 AM
scorke's Avatar
Head studs protect againt stretching which is caused from running higher in cylinder pressures caused by increased boost or compression....
Rod Bolts wouldnt be a bad idea..
Scorke
Old May 17, 2007 | 10:27 AM
Zodiac13's Avatar
from what i heared from a friend you can get the stock block to rev to 10k with a 2.0 build but 1. is that safe even if you do build it up and 2. what do you need to do to do that?
Old May 17, 2007 | 10:28 AM
coolnick's Avatar
How do head studs protect against the damage caused by revving high?
Do you know what head studs do? Do your pistons hit the head?
Scorke
Uhhh...
Yeah
Old May 17, 2007 | 10:29 AM
Ralph's Avatar
I ride the rev's out near 8000 only during a 1/4 pass, IX's have a shorter 4th gear than VIII's .
Old May 17, 2007 | 10:36 AM
iTune's Avatar
RPMs kill engines.....
Originally Posted by iTune
The biggest enemy to your rods/rod bolts is engines revs. The higher you rev the more stresses multiply.
For instance, this is a Honda K20A(for example only):
Piston acceleration at TDC for K20A @ 8400 rpm = 4300 G's
Piston acceleration at TDC for K20A @ 9500 rpm = 5600 G's
As you can see, the acceleration of the piston multiplies a lot as revs increase. Of course, this particular engine has a 86mm bore and a 86mm stroke, it's a square engine. It also has a rod ratio that supports high revs from the factory. This is not a 4G63, as the 4G63 is a much different engine. But it illustrates my point very well.
This is not even taking into account the valvetrain and what it's physical limits are in regards to valve float. I'm not too sure what the max RPM is of the stock valvetrain on the 4G63 is. But, if you plan on running high RPM's, upgraded valve springs/retainers are a must, no matter what you do with the bottom end.
I would recommend staying within 500rpm of stock fuel cutoff. This is a good area to stay in with the stock valvetrain and stock bottom end.
https://www.evolutionm.net/forums/sh...9&postcount=17
The rod ratio of the stock 4G63 is not condusive to high revs. I'm sure some people have pushed the limits of the stock bottom end and valvetrain....but i don't recommend pushing it too far over stock.
On the stock turbo, i run 7800rpm on the stock bottom end and stock valvetrain. Once i install my HKS 280 cams, i will NOT raise my revlimiter at all over 7700-7800 rpm on the stock valvetrain due to aggresive ramp rates, which will only exacerbate valve float issues. Although, the stock bottom end should be able to handle the piston acceleration @ 7800rpm.
CJ
Old May 17, 2007 | 10:38 AM
iTune's Avatar
you can build anything with the correct parts and a rod ratio that supports high revs. but then it's not a stock block..... it's a built block.
CJ
Old May 17, 2007 | 10:40 AM
scorke's Avatar
Originally Posted by coolnick
Uhhh...
Yeah
Sorry, woke up on the wrong side.
Rod bolts would help, head studs would not.
Rod bolts are not nec. to rev to 8k.
Scorke
