EvoIX w/ 03 xfercase???
Old May 18, 2007 | 07:57 AM
kaonashi's Avatar
Will this work? im thinking about just buying a Evo9 crate motor, and I have a 03 5spd tranny, xfercase that i will be using with the motor. But is it possible for me to use the old parts i know the tranny is good but not sure on the xfercase.
Old May 18, 2007 | 07:58 AM
smokedmustang's Avatar
'03 TC won't work in a "9"
Old May 18, 2007 | 08:00 AM
kaonashi's Avatar
dang there goes that plan
Old May 18, 2007 | 08:01 AM
sharkm87's Avatar
fimotorsports's Avatar
it will work
Old May 18, 2007 | 08:02 AM
kaonashi's Avatar
IM CONFUSED inform me please
Old May 18, 2007 | 08:03 AM
mrcox's Avatar
I think he ment he is puting a evo 9 motor and trans in his 03 evo 8 and wants to know if his transfer case will bolt up to the evo 9 trans.
Old May 18, 2007 | 08:04 AM
I was looking for a TC for my '03, and was told an '04 would fit, but nothing past an '05 model would work-maybe it works the other way then. fimotorsports has more accomplishments in his "sig" then me, so go with his answer.
kaonashi's Avatar
its Evo 9 long block w/ 03 5spd tranny and 03 TC
Old May 18, 2007 | 08:05 AM
Steve@NoLimitmotors's Avatar
it will work, but you need to eliminate the ACD. All 3 lights will be on in the cluster, best bet is to unplug the pump behind the driver side fender so it doesnt pump dry.
Old May 18, 2007 | 08:06 AM
I am confused now. DO NOT LISTEN TO MY REPLIES!!
you need an engine harness, evo 9 ecu to control the Mivec too man, IDK if I'd get involved with that swap if I were you
Old May 18, 2007 | 08:07 AM
well you def cant put an 05/06 t case in ur 03/04 because they have ACD and you cant operate it, it would just blow up
but an 05/06 can use an 03/04 t case and just eliminate the ACD, see what I mean?
Old May 18, 2007 | 08:08 AM
kaonashi's Avatar
Im getting all of that stuff, My 03 block has a chip in it i would say so i need a replacement and id rather just swap for better since i have to.
kaonashi's Avatar
gotcha thanks guys. BTW if this is the case ill have a 03 Head with 26k miles on it for sell soon and the rest of the parts of the 03 block
