EvoIX w/ 03 xfercase???
Old May 18, 2007 | 08:09 AM
smokedmustang's Avatar
Originally Posted by Steve@NoLimitmotors
well you def cant put an 05/06 t case in ur 03/04 because they have ACD and you cant operate it, it would just blow up
but an 05/06 can use an 03/04 t case and just eliminate the ACD, see what I mean?
I always see what you mean when you spoon feed me! Thanks bro!
Old May 18, 2007 | 08:10 AM
sabastian458's Avatar
If you have an Evo 8, then it will work with out ACD, but you would need to find a way to control the mivec. If you have an Evo 9, then you need to find a way to bypass the ACD.
The Evo 9's t/f case uses the same housing section (well the part that bolts to the trans) as the Evo 8. MMNA redesigned the outer section to accomedate the ACD system.
kaonashi's Avatar
Perhaps there is a god !
Old May 18, 2007 | 08:11 AM
kaonashi's Avatar
so how would i go about bypassing the acd since the TC wont have it?
Old May 18, 2007 | 09:01 AM
DaWorstPlaya's Avatar
Guys, he's trying to attach an EVO9 motor to his EVO8 with 2003 EVO8 5 speed tranny and 2003 TC. Yes they should connect up without any issues. The EVO8 and EVO9 trannies are identical except for gear ratios and since you aren't using/upgrading to an EVO9 tranny the ACD TC doesn't even matter.
The only thing you will need to get are, EVO9 engine wiring harness and EVO9 ECU. ACD lights and switch don't even matter because you will be using the 03 EVO8 tranny and TC sans ACD.
Old May 18, 2007 | 02:02 PM
^ what he said.
Old May 18, 2007 | 02:53 PM
Jeff_Jeske's Avatar
I dont think I would spend the money for a mismatched crate motor.
Find a good deal from a junk yard and call it a day. If you want more have a performance shop build it for you.
jimbo74
Lancer Tranny/Drivetrain Tech
16
Mar 6, 2024 02:46 AM
kaonashi
12
Nov 26, 2013 07:11 PM
kaonashi
12
Jul 4, 2012 06:01 PM
Cirielmd
May 28, 2010 08:23 PM
icedoutsk8er
Dec 2, 2008 07:20 AM
