bov for over 26psi
Old May 18, 2007 | 11:03 AM
frycztech's Avatar
bov for over 26psi
I tryed searching but i couldnt find an answer for a bov that people recomended for over 26psi. iam running a ems do you recomend that i still keep a rec. bov?
Old May 18, 2007 | 11:36 AM
Chris@nolimitmotors's Avatar
Run a tial bov.
Old May 18, 2007 | 11:43 AM
mikesevo8's Avatar
APS gets my vote
Old May 18, 2007 | 11:47 AM
meckert's Avatar
Forge
Old May 18, 2007 | 11:50 AM
swordfish's Avatar
Tial and be done since you are running a stand alone.
jeff
Old May 18, 2007 | 12:04 PM
EvolutionIXSE's Avatar
Try this one from Turbo XS, it can hold up to 35 psi, copy and paste this link http://www.jcwhitney.com/autoparts/P...g+bypass+valve
I have one that I ran on my elcipse. The boost is up to 35 psi, I have a silver one. It actually fits on the EVO as basically a direct replacement and can be used as a diverter valve or vent into the atmosphere. I took my metal BOV of the other day just to see how close it came to fit, and I was able to pop it right into place. You will need to get a tube if you plan to ricurculate, I ran it both ways, but I got better gas mileage with it recirculated. I don't have any mods so I'm actually going to put it in the classifieds for $75. But you can get a brand new one for about 100 bucks more.
If you have ems you should be able to run it however you want as long as the car is tuned for it. This BOV is still very loud reccirculated so I would go that route.
Old May 18, 2007 | 12:08 PM
steevo's Avatar
Go Fast Bits. They say it is good up to 100psi. Here is my review of it I just made:
https://www.evolutionm.net/forums/sh...d.php?t=271638
Best of both worlds.
Quote from their site:
What boost level can I use with a GFB blow-off valve?
Any level you like! The design of all GFB blow-off valves means that you can run boost levels that will more likely blow up hoses before the valve will leak. Because of the acetal seat the piston makes a perfect seal, and our valves have been tested in the factory to pressures of 110psi (if you can blow up one of our valves on a car we'd like to hear about it!).
Old May 18, 2007 | 12:20 PM
DRFTKNGG's Avatar
Tial...
Old May 18, 2007 | 12:29 PM
Soon2BEVO's Avatar
I run a Tial on a flash and I do NOT reccomend it. I can deal with it since I dont drive the car much and I dont drive on the highway, but if I did, Id get a recirculated one.
Old May 18, 2007 | 12:46 PM
Jeff_Jeske's Avatar
Most stock metal DVs are going to hold 26psi. If it leaks crush mod it and you'll be good to go.
Old May 18, 2007 | 12:48 PM
Gary 805's Avatar
I use the Metal JDM 9 MR bov. Works perfect.
Old May 18, 2007 | 12:58 PM
Waz996's Avatar
I got the Forge Evo15 from TTP, fully recirculating.. Price is great and reply from TTP is instant! It's got several springs for several pressure levels according to your boost settings (though u can get the Forge RS which is adjustable by a knob but unavailable and more expensive).
I'm still waiting for it, will post when installed.
Wael
Old May 18, 2007 | 02:58 PM
Jeff_Jeske's Avatar
If I had an EVO 9 I wouldnt' change the DV unless upgrading the turbo and running 28+ psi.
With the 50 trim you may need to upgrade depending on boost.
Old May 18, 2007 | 03:13 PM
mplspilot's Avatar
forge adjustable here.
Old May 18, 2007 | 04:17 PM
Blkstreak's Avatar
APS works well.
