Making a leak tester
Old May 20, 2007 | 01:53 PM
QwikEVO's Avatar
I've done a search and there was a thread a while back linking you to how to make a boost leak tester. Thing is that the link had the wrong size OD radiator hose for our size turbos.
My question is, what is the OD that I will need to fit around our turbo's inlet?
Thanks.
Old May 20, 2007 | 07:47 PM
kjewer1's Avatar
It's roughly 2.5" The Fernco plumbing couplers are sized for schedule 40 or similar PVC/ABS pipe, which has a wall thickness of about 1/4 inch. So a 2" ferco would have a ~2.5" ID. It's flexible enough to make it work. I haven't built one with a fernco for the EVO, but I'm betting this will work.
Old May 20, 2007 | 10:30 PM
QwikEVO's Avatar
so I need something with a 2.5" ID if I'm reading you correctly...
Old May 20, 2007 | 10:33 PM
SPOOLEDTSiAWD's Avatar
I just use a 2" plumbing coupler from Lowes and it fits snug over the inlet
Old May 21, 2007 | 01:16 AM
kjewer1's Avatar
Roughly, like I said. I add that disclaimer because the Ferncos are flexible, if you get a 2.5" silicone coupler, it's not.
Old Jun 7, 2007 | 05:12 PM
03lan-evo's Avatar
ok so ive been meaning to make one of these. does any one have a part number?
also what turbos are you running? im using a 30R
Old Jun 10, 2007 | 07:43 PM
DynoFlash's Avatar
You can make it out of any pipe the size of the turbo inlet
