Pre-throttle body pressure for manual boost controller
Old May 20, 2007 | 04:03 PM
KY's Avatar
KY
I am putting in a different turbo with an external wastegate. The turbo I have doesn't have a nipple on it for pressure and I can't get one on it either. I was wondering if anyone knew of a good source for pressure for my Forge UNOS. Thank you
Old May 20, 2007 | 06:55 PM
AfireINSIDE's Avatar
go to ATP's web site and get a quick tap
Old May 20, 2007 | 07:01 PM
KY's Avatar
KY
Ok, I will check it out.
Old May 20, 2007 | 07:19 PM
KY's Avatar
KY
I wonder if I could tap into the coupler on the LICP pipe. It would be a whole lot easier for me.
What do you think?
Old May 20, 2007 | 07:27 PM
kjewer1's Avatar
If you're using a steel or stainless steel UICP/LICP, just tap that for the 1/8th NPT fitting of your choice. Been doing that for as long as I can remember.
Old May 20, 2007 | 07:30 PM
KY's Avatar
KY
Thanks
Old May 20, 2007 | 08:47 PM
KY's Avatar
KY
There is an unused nipple on my intake pipe. Can I use this?
Old May 20, 2007 | 09:36 PM
kjewer1's Avatar
That pipe isn't pressurized, it's before the turbo.
Old May 21, 2007 | 03:00 AM
KY's Avatar
KY
Ok, so any of my intercooler pipes will work? Thanks
Old May 21, 2007 | 07:49 PM
kjewer1's Avatar
Yes, LICP and UICP should cover all of your intercooler pipes. You can also tap your IC endtanks if you want to make this more complicated than it needs to be.
Old May 21, 2007 | 09:42 PM
KY's Avatar
KY
Thanks, I used the LICP
