4th gear gone
Old May 21, 2007 | 05:11 PM
mikiblueeyes's Avatar
4th gear gone
As I am cruzing down on the freeway at about 60mph accelerating to 80 to pass traffic i hear that grrrrrr and since then I have no 4th gear.
All other gears work the same way. Does any one had simmilar issue? What does it take to fix it???
ideas, thanks
Old May 21, 2007 | 09:01 PM
nobody knows?
Old May 21, 2007 | 09:04 PM
joshesh's Avatar
do you have an MR?
Old May 21, 2007 | 10:07 PM
no its a 5 speed 2003 evo no drags, and only 37000 miles on it.
Old May 21, 2007 | 10:10 PM
Ebirns99's Avatar
I have an 06 MR and mine does the same, could be a synchro
Old May 22, 2007 | 08:10 AM
bump
Old May 22, 2007 | 08:24 AM
sr20det91's Avatar
Chances are you broke the gear. Usually if its a syncro it will grind, but eventually pop in. It could possibly be the shift linkage, but that remote at best, as it would probably effect other gears as well.
Your best bet IMO would be to send the tranny off to someone like Sheppard racing and have it rebuilt. You can find used trannys, but they will usually cost around the same as a rebuild and you will not know what your getting.
As a side note. If you did have a gear grenade on you thats means theres shrapnel (gear parts) floating around in your tranny. Eventually they will wedge themselves where there not supposed to be and cause much more damage, in turn upping your rebuild cost considerably. So if your planning on going that route, I wouldnt drive the car.
Old May 22, 2007 | 12:40 PM
DaWorstPlaya's Avatar
If the 4th gear is gone he should be hearing a lot of noise from his transmission. Lots of clunking and clanking from all the 4th gear pieces floating around. If there is no noise, your shift linkage may be damaged there by not doing anything when you try to shift into 4th. If your synchros are toast it will grind everytime you try to shift into that particular gear.
Goodluck.
Old May 22, 2007 | 12:48 PM
Altr_Evo's Avatar
sounds like a bad synchro
Old May 22, 2007 | 04:45 PM
FLAEVO's Avatar
My 4th gear went ,it felt like it poped out of gear.Drain the oil if there
are big chuncks of metal on the magnetit the gear.Mine had 76000 mls
on it.40000 mls with gt35.
Old May 25, 2007 | 10:45 AM
looks like i will get new transmission. its at the stealership now. expensive summer present gonna cost over 3K to get fixed.
Old May 25, 2007 | 11:16 AM
the chosen one's Avatar
send it to shepherd for a rebuilt $ 880
Old May 25, 2007 | 01:23 PM
yikez's Avatar
+1
Old May 25, 2007 | 01:26 PM
pac74's Avatar
where are they located? my fifth gear grinds all the time when I shift fast.
Old May 26, 2007 | 09:12 AM
shep will charge more, due to every gear needs to be rebuild. I think $800+ is for working tranny rebuild. On average its 200$ per gear.
