0 oil pressure @ idle in high altitude area
Old May 22, 2007 | 01:24 PM
wokuku's Avatar
I searched the problem I am having but I don't see anything close to what I have been experiencing.
I drove my car over to the reno area (~8000 feet high) and I noticed that the oil light turned on whenever I was idling (~700 - 800 RPM) in normal driving temperately. My defi oil pressure gauge showed that I had 0 oil pressure!!! I had to keep bumping gas to keep it out of 0 pressure. I checked the oil level after parked my car for couple hours and it was full so I wasn't sure what was wrong with my car.
My car doesn't have this problem in the bay area which is around sea level. I use mobil 1 10w-30 oil so is it possible that this weight is not suitable in high altitude area?
Old May 22, 2007 | 01:33 PM
Jdav79's Avatar
Maybe the Oil pump? Not quite sure, however if you have 0 pressure while Idling I would avoid driving it altogether.... If it is the pump you don't want it going out on you while you are driving at say 60mph, that would suck.
When was your last oil change? What filter did you use?
Old May 22, 2007 | 02:05 PM
wokuku's Avatar
My last oil change was done about 3000 miles ago and used OEM oil filter. I don't have any problem when driving at near sea level though. I get around 4.0 psi while idle and around 40 psi @ around 3,500 RPM which seems normal.
Is there anyway to check the oil pump to see if it is failing?
Old May 24, 2007 | 09:10 AM
20psiMR's Avatar
Thought it was supposed to be 10psi at idle? Pretty sure actually.
Old Feb 17, 2008 | 08:56 AM
Boosted GP's Avatar
I get 14psi plus at idle (mobil 1 5w40) at 80 deg C
Mike
Old Feb 17, 2008 | 11:45 AM
Kracka's Avatar
I see about 17psi on my Defi gauge at idle (Mobil 1 10W-30, Mitsu filter). Something is wrong with your car.
Old Feb 17, 2008 | 12:12 PM
cssaddictm4's Avatar
Mike
Holy crap that is hot! 176*F! Zero oil pressure anytime is not good.
Old Feb 17, 2008 | 09:35 PM
Boosted GP's Avatar
194 -221*F (90-105*C) is normal operating for an evo... specially on the track.
I call it quis on the track at 239*F (115*C).
I would say anything over 248*F (120*C) is starting to get on the high side, but i have seen guys run their cars to 284*F (140*C)!!!!! thats HOT!
v8<turbo4
Jun 9, 2014 08:44 AM
Capes
Feb 9, 2014 02:27 PM
bandit09
May 16, 2012 04:39 PM
MitsShado
Lancer Troubleshooting
10
Mar 21, 2012 12:58 PM
batdorf9
Jul 18, 2011 05:31 PM
