Clutch longevity
Old Jun 1, 2007 | 11:05 AM
deadbeatrec's Avatar
ACT HDSS is the shizit! holding 500ft/lbs its the cheapest and most reliable.
Old Jun 1, 2007 | 11:13 AM
Soon2BEVO's Avatar
ACT is the way to go for price and performance. It holds great power and is CHEAP. No problems what so ever. All that complaining about shifting at high rpm problems seems to be a myth of sorts. Ive never once had a problem. As long as its installed correctly.
Old Jun 1, 2007 | 12:10 PM
erioshi's Avatar
Originally Posted by thebluesky
I have a stock clutch with 70k on it and it still has plenty of life left in it. THis clutch has been launched and driven fairly hard as well. Only reason I'm even swapping it now is because of convenience and the fact that it probably won't hold up to the power I'm going to try to lay down.
Basically, the life of any clutch you use depends on how you drive, plain and simple.
What he said. My car was at about 40k and modded when I pulled the engine because of a spun bearing caused by stretched rod bolts.
Even after many, many track days (road course) and quite a bit of spirited driving my OE clutch disk had all the relief vanes clearly visible - the disk looked a bit worn but by no means near the end of it's life. The flywheel & pressure plate do show some hot spotting, but nothing too serious. I will probably reassemble everything with a new OE clutch disk and a better pressure plate.
Old Jun 1, 2007 | 12:18 PM
L80Killa87's Avatar
What about the xtss?
Old Jun 1, 2007 | 03:04 PM
diablo2184's Avatar
so mitsu will warranty the clutch? mine is stock....
Old Jun 5, 2007 | 02:44 PM
JJsEvo8's Avatar
The dealer I worked with warranties it for one year. However, from the factory Mitsubishi DOES NOT warranty the clutch, but will warranty the rest of the drivetrain. Unless, of course, you install an aftermarket clutch.....
Old Jun 5, 2007 | 02:55 PM
erioshi's Avatar
After digging for a bit, it looks like the ACT HDSS will be what I install in my car. While I don't need it to support drag starts, I will be adding power and am concerned about overpowering the stock clutch.
Now I just need to weigh up the stock flywheel and see how much relevant mass a ~10 lb flywheel will save...
