What is the max boost I could run safely with my gt35r kit, with 93.
Old Jun 1, 2007 | 04:06 PM
blackonblackevo's Avatar
I was thinking about installing my gt35r kit, I have forge manual boost controller.
My car is currently at 338 to the wheels, with the stock turbo and supporting mods, If I was to install the gt35r kit, What would be the maximum boost I could run on my evo 9 without blowing the engine, without having the turbo kit tuned? Thank you.
Old Jun 1, 2007 | 04:15 PM
bboypuertoroc's Avatar
Veteran: Army
Didn't you just ask this question elsewhere?
Old Jun 1, 2007 | 04:16 PM
Ludikraut's Avatar
Without a tune I wouldn't boost more than WG spring pressure ... ~15 psi.
l8r)
Old Jun 1, 2007 | 04:29 PM
kreionic's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=274488 ????
Old Jun 1, 2007 | 04:44 PM
8URVTEC's Avatar
I will say after you get tuned, 24 to 25 psi on pump and 37psi to 38 psi on C16! I am pushing 37psi on C16!!!!!
Old Jun 1, 2007 | 04:49 PM
G20's Avatar
G20
hard question, no specific answer but without tuning, the more you push the higher chance the car blow up so use your common sense.
Old Jun 1, 2007 | 04:50 PM
Does anybody know how boost is given for every click on a forge manual boost controller. Thanks.
Old Jun 1, 2007 | 04:56 PM
If I do install my turbo kit and my manual forge boost controler, and turn it up to 15 psi would my a/f ratios be ok/safe, with my stock evo 9 injectors and 255 fuel pump?
Old Jun 1, 2007 | 04:58 PM
newimportowner's Avatar
you do have a boost gauge right
Old Jun 1, 2007 | 05:00 PM
I have a ziertronix kit with every option but I do not know how to install it, no i do not have a boost guage.
Old Jun 1, 2007 | 05:04 PM
34Turbo's Avatar
Don't boost untuned! Tuned on the stock block 23-24psi on pump and 28 on alky would be safe. With some race gas you may hit 30... You can run a lot more boost with a built block though. Good luck!
Old Jun 1, 2007 | 05:14 PM
kreionic's Avatar
You really should put in your boost gauge before you upgrade the turbo. Use your head man
Old Jun 1, 2007 | 05:25 PM
esevo's Avatar
You HAVE to upgrade the injectors! anything over 15 psi will set it over 100% duty cycle (with out alky). Also go MAP at 25 psi my maf was done... with 820cc injectors with maf at 26lbs with alky. 20-21 on 91. check out my sig and my old evo's set up...
Old Jun 1, 2007 | 06:09 PM
2theMAX's Avatar
I am running a GT35R w/ stock injectors at 15-17 psi. I adjusted the fuel maps a little w/ Ecuflash. The car is running pretty rich to be safe until my tune.
Old Jun 1, 2007 | 06:10 PM
2theMAX's Avatar
I forgot to mention: I have 0 knock using 91 octane.
