Stock Intake Manifold Question..
Old Jun 6, 2007 | 05:18 PM
kingman4's Avatar
Originally Posted by kjewer1
You've managed to thoroughly confuse me now. There is no appreciable vacuum in the intake pipe. The only vacuum worth mentioning is from the intake manifold via the PCV valve. Once that is disconnected, there will be positive pressure in the crankcase pretty much 100% of the time. If I'm understanding you at all, you're talking about leaving the vent to the intake pipe hooked up and venting the PCV port, which would indeed be a bit unconventional. People usually do it the other way around, which porks trims since you still have a solid vacuum applied to the crankcase via the PCV valve and an open system with the intake port vented.
What poeple with high HP setups tend to do is to vent both the PCV and the Intake ports to atmosphere. Plug the hole in the intake pipe and in the intake manifold, and drive it on.
If none of this applies to your qestion still, you're on your own.
Whats the best way to plug the hole in the intake pipe?
Old Jun 6, 2007 | 09:55 PM
kjewer1's Avatar
I've always run one that didn't come with that port installed. But, a simple vacuum cap from an autoparts store will suffice, there is very little pressure/vac in that pipe. Or for the 1 cent ****box mod, a 2" piece of rubber hose with a bolt shoved in the end of it.
fostytou
359
Oct 23, 2025 09:54 AM
tkklemann
For Sale - Cars For Sale
24
Aug 5, 2014 08:49 PM
sabastian458
25
May 8, 2013 12:49 PM
David Buschur
Nov 23, 2010 05:57 PM
fostytou
Oct 18, 2009 08:53 PM
