Hallman Boost Controller Q&A...
Old Jun 3, 2007 | 09:35 AM
Ultimate CC's Avatar
Any questions post em here, from install to new releases...
Old Jun 3, 2007 | 09:37 AM
Warrtalon's Avatar
Advanced?
Old Jun 3, 2007 | 09:47 AM
opps haha...please delete...
Old Jun 6, 2007 | 05:58 PM
AhmadHasib's Avatar
I looked at a DIY for installation of a boost controller but seems to be a little iffy to understand for me. Is there another write up for installing a boost controller on our cars?
Old Jun 14, 2007 | 01:50 PM
mautofied's Avatar
Hallman Pro RX boosting @10psi
Just put the hallman Pro RX on my 05 Evo and I went from peaking @ 20psi (using the factory boost controller) to 10psi. Is there something I missed? Do I have to get the ECU flashed to override the factory BC?
Everything is as it should be as far as the vacume lines.
Any help with this would be awsome.
Old Jun 14, 2007 | 03:28 PM
G20's Avatar
G20
It's kind of trivial but... did you turn the boost knob clock-wise?
Old Jun 14, 2007 | 03:39 PM
bboypuertoroc's Avatar
Veteran: Army
^ +1.
Are you in any way plugged into the stock BCS?
Old Jun 14, 2007 | 05:30 PM
mautofied's Avatar
Thumbs up still boosting at 10psi
The stock BCS is capped (ran line from one inlet to the other)
Original MBC setup was WGA to MBC to a T on the BOV line.
Just tried a different setup... still 10psi. WGA to MBC to Intercooler piping (next to WGA)
I have turned MBC all the way up and back down, this had absolutely no effect.
Old Jun 14, 2007 | 05:43 PM
mautofied's Avatar
do I need to put the heavy spring in my MBC? I'm running the light spring setup for 5psi above stock.
Old Jun 14, 2007 | 05:46 PM
Veteran: Army
Do a boost leak test.
Old Jun 14, 2007 | 05:55 PM
Veteran: Army
Oh yeah, negative on a retune needed to override stock BCS.
Old Jun 14, 2007 | 05:58 PM
mrbkkt1's Avatar
You will need the heavy spring if I remember right. The light spring was for lower boost cars.
I forget, I installed mine so long ago.
also, you will be bypassing all the stock boost controller lines, and DO NOT reuse those lines, because they have pill restrictors in them.
Old Jun 14, 2007 | 06:10 PM
mautofied's Avatar
I'll change the spring and give it a go.
Also, whats the correct way to do a Boost Leak Test?
Old Jun 15, 2007 | 07:24 AM
mautofied's Avatar
I think I may of found the problem, I went to change the spring last night in the Hallman MBC and the ceramic ball was MISSING!!
Old Jun 15, 2007 | 09:30 AM
AhmadHasib's Avatar
my ball might be dirty, I needa open it and lube it up
