MBC vs EBC...
Old Jun 6, 2007 | 01:54 PM
PorkRoll's Avatar
I just switched from a greddy profec ll b to a Hallman and my spool is so much quicker, i would say almost 500rpm quicker. Go with a manual, hallman with the rx kit then you can mount in in the cabin.
Old Jun 6, 2007 | 02:03 PM
kreionic's Avatar
Then you had no idea how to set your profec up
Old Jun 6, 2007 | 02:19 PM
milo's Avatar
I would go with a EBC....I personally run the Blitz Dual SBC type R.
Old Jun 6, 2007 | 03:21 PM
Speed Corps's Avatar
Former Vendor
I got the profec b and I love it. Quick spool and no boost drop.
Old Jun 6, 2007 | 03:49 PM
Jakeg97's Avatar
mbc with cockpit control ftw
i have mine set next to my boost gauge for accurate readings
Old Jun 6, 2007 | 05:51 PM
ImJoey's Avatar
That AEM Tru boost is sweet.I like the "killing two birds with one stone" idea.
Old Jun 6, 2007 | 05:52 PM
UR EVO_RS's Avatar
Go with EBC, quicker spool for sure
Old Jun 6, 2007 | 06:00 PM
dsmfan95's Avatar
Originally Posted by NoTec
I have also been reading and actually witnessed a Greddy pb2 maintain nice stable boost. Some of the ebc can be manipulated or setup to maintain 21 psi to readline without the use of a high pressure wg actuator. It seems like the price tag is worth it if it offers that type of functionality.
There are more than one boost controller that allows you to compensate for taper. Of course you won't be able to completely eliminate it, but I had the stock turbo running 22psi from 3500-8000rpms. We saw nearly a 30whp gain on pump gas by having the stock turbo hold 22psi rather than tapering off to a normal 18-19.
Old Jun 6, 2007 | 09:27 PM
Clos23's Avatar
I had a mbc, but I got tired of having to readjust it everytime I'd add a mod. With my ebc it's pretty much dead on no matter what mods i add. Plus my mbc had a tendency to go haywire and spike whenever it got colder.
Old Jun 7, 2007 | 05:57 AM
bmfgsxr's Avatar
do you have to compensate for weather differences often with an ebc? i have read that you have to change an mbc with different weather conditions often.
Old Jun 7, 2007 | 06:23 AM
NoTec's Avatar
If you want to maintain a specific boost target, yes you have to adjust it depending on weather conditions. The ebc's are acitve controllers and regulate by themselves. If properly set up, I don't think the ebc's can be matched.
Old Jun 7, 2007 | 06:50 AM
bmfgsxr's Avatar
thanks for the info.. who makes the best ebc's out there, and how much effort does it take to set up?
Old Jun 7, 2007 | 07:01 AM
EvoDan2004's Avatar
Does a ebc spike like a manual would?? If not don't you think trq would be a little less because there is no spike...
Old Jun 7, 2007 | 07:12 AM
nutrulz's Avatar
Spikes are semi-dangerous and not optimal. So yeah, peak torque will be lower, but total torque could be higher (read: no taper).
Old Jun 7, 2007 | 07:18 AM
Slick-IX's Avatar
nice info in this thread
