Boost Numbers???
Old Jun 9, 2007 | 11:20 AM
boostin@27's Avatar
Boost Numbers???
what boost numbers should i be running on my 03 evo 8. i have 320whp, and the following mods, 20g turbo, ams fmic kit, injen intake, mr exhaust manifold, eselir dp, ultimate racing tp, greddy tic cbe, walbro fuel pump. i have the greddy profec boost controller, i just want to know what set, gain, set gain, limiter, warning i should be running with the mods i have and the power i have.
thanks
Old Jun 9, 2007 | 04:07 PM
pulley1fan's Avatar
Dont know about the Profec but with those mods and a tune, you should be fine with up to 25-29 psi of boost.. peak not spike. Factory boost for those years is 21-23 I believe.
Old Jun 9, 2007 | 04:20 PM
bluebyu36's Avatar
25-29 pounds what are you high .......
factory boost is 19 taperin to 16
22 pounds the most with those mods i have a fully built block and i do not turn it up past 24....
Old Jun 9, 2007 | 05:22 PM
urslo4n8's Avatar
NO WAY should you be runnin higher than 23-24.....thats if you can get 93 octane.
Old Jun 9, 2007 | 05:39 PM
IEXCELR8's Avatar
no cams, 21 psi-11.3 afr
Old Jun 11, 2007 | 08:54 AM
boostin@27's Avatar
ok but what set, gain, set gain, and warning should i be running?
Old Jun 11, 2007 | 08:58 AM
Warrtalon's Avatar
Please edit this, or the mods should delete it.
Boostin, dude, you have an EBC - you have to know how to use it. Otherwise, you should be using an MBC.
arpad
179
Feb 9, 2020 03:51 AM
LoveBoost
29
Jan 30, 2008 10:19 AM
PorkRoll
23
Oct 20, 2007 04:03 AM
wheredafucrwe
Oct 26, 2004 12:10 AM
arpad
Apr 12, 2004 08:23 PM
