O2 housing question
Old Jun 11, 2007 | 10:57 AM
mortman212's Avatar
O2 housing question
I have an 03 EVO with a AMS tubro back waiting to be installed should I upgrade the O2 Turbo outlet housing at the same time. And how hard of an installation is it. Any have any links to a good install. Thanks
Old Jun 11, 2007 | 11:02 AM
TeStUdO's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=239047
It is definitely worth installing. You should change to a 10.5 hotside as well. Try the "How To" section and you will see a lot of threads on it.
Old Jun 11, 2007 | 11:35 AM
Lowell787's Avatar
Still pretty easy, but a little more involved, I'd recommend the 10.5 at the same time as well if you cna find one. I ended up porting my O2 housing because I was broke. Definitely let everything cool and spray the bolts to let them sit overnight or you'll never get it off.
Old Jun 11, 2007 | 12:00 PM
powdevo13's Avatar
i still have one i am waithing till i do head studs maybe it is because i am lazy
Old Jun 11, 2007 | 01:02 PM
8UpUrV8's Avatar
You dont really have to do it at the same time, it wont make things much easier... like if you were taking off your manifold and adding a 10.5- THAT would be a real good time to upgrade.
But its only 2 bolts holding in the downpipe so its not so important to do them both at the same time.
