Boost too low
Old Jun 13, 2007 | 08:36 AM
MitsuJDM's Avatar
Boost too low
Yeah yeah, I can already hear you guys "SEARCH!!!!" but I did, for 2 days and have found some useful info but nothing specificly for me.
Anyway, I've been a member for a little while with a boosted Mirage, but I just bought an EVO a few days ago. It has a Hallman MBC (not sure which model specificly) and a autometer boost gauge. The first few days, the car boosted 19-20psi with a taper to 16-17 psi like normal. Just this morning the car won't go past 15psi, and will taper to almost as low as 12-13psi. I haven't touch anything. The car doesn't feel significantly slower but I can feel some slightly lost power.
Many people say boost leak and then in all the topics I've search it just turns into to "why didn't you search" and little arguments :P I know 11psi is stock wasteate, but it's not that low.
But anyway, the car is all stock except the MBC and I didn't touch it, just this morning I can't get over 15psi. Any suggestions?
Old Jun 13, 2007 | 08:39 AM
deadbeatrec's Avatar
are u sure the boost controler is hooked up the correct way? u may have it in wrong and are just getting wastegate pressure.
Old Jun 13, 2007 | 08:40 AM
TeStUdO's Avatar
Make sure the vaccuum lines are still on the MBC.
Old Jun 13, 2007 | 08:45 AM
mifesto's Avatar
if ur spiking to 21 but tappering that bad... your MBC is installed fine.. its a major boost leak
Old Jun 13, 2007 | 08:46 AM
4-BNGR's Avatar
check your lines and caps.
Old Jun 13, 2007 | 01:12 PM
MitsuJDM's Avatar
No spiking to 21psi, it goes the 14psi and tapers to 13psi. But anyway, I already checked all the MBC to wastegate and compross housing lines. But I think I may have found the culprit.
As I said the car still feels strong... well I found a pin hole and loose line from the boost gauge to the intake manifold so I'm 90% sure it's just that :P It's always the little stupid things...sigh.
It's pouring out now so when I get a chance to fix it, I'll come back and let you guys know how it works. I hope it's just that and nothing else. After all the boost issues with the Mirage I'm about all boosted issued out... sigh
MitsuJDM
19
Nov 9, 2016 03:47 PM
EGbeater
Jul 22, 2008 10:32 AM
Chukee_R
17
Jul 2, 2007 02:03 PM
joek84
21
Jan 2, 2006 06:19 PM
2jzEVO
Sep 27, 2005 11:13 PM
