Stock UICP no go.
Old Jun 13, 2007 | 09:54 AM
SuPeRNeT's Avatar
Stock UICP no go.
I was running the stock UICP and a AMS LICP, my car was having very high intake temps, and knocked, because my pipe was rubbing on the radiator inlet and side..
So i picked up a ETS UICP and my car has 0 knock, spools faster, and pulles harder.. any one running just the LICP get the UICP. The stock one is Bottleneck and is too close to the radiator..
Old Jun 13, 2007 | 10:08 AM
4-BNGR's Avatar
No problems here. Are you running the stock air box?
Old Jun 13, 2007 | 10:36 AM
SuPeRNeT's Avatar
Apexi intake
Old Jun 13, 2007 | 10:37 AM
bvdawg13's Avatar
well good thing u upgraded then! lol
Old Jun 13, 2007 | 10:40 AM
evoixbri's Avatar
get an intake tube like the hks or the aem to go with your apexi intake. Thats what i did. and it pulls and sounds better. seems alot easier to breathe.
Old Jun 13, 2007 | 10:43 AM
TeStUdO's Avatar
Placebo effect. You cant back that statement up with numbers.
SuPeRNeT, what was the difference in intake temps and how were you measuring them?
EVOL2003's Avatar
stock uptop and ams lower no prolems...ams installed...look elsewhere for your problem imo
Old Jun 13, 2007 | 10:56 AM
Duby's Avatar
running Nisei Engineering 1018 Lower Intercooler Pipe with no probems. good thing for steel too, must have bottom it out multiply times and its scratched to $#%, an aluminum one would have been destroyed by now.
Old Jun 13, 2007 | 11:59 AM
4-BNGR's Avatar
I would check your tune (fuel requirements).
Old Jun 13, 2007 | 12:41 PM
SuPeRNeT's Avatar
15-20 deg, evoscan same day... With my old pipe id pull over and feel it and almost burn my hand, now its slightly warm..
Old Jun 13, 2007 | 12:45 PM
Evo8yurAMG's Avatar
i need to get an UICP
Old Jun 13, 2007 | 12:48 PM
SuPeRNeT's Avatar
Get a mini battery too .. Loses weight and gains space, lots of space.
Old Jun 13, 2007 | 12:52 PM
dudical26's Avatar
EvoScan measures the temperature in the MAF, which is before the UICP, and therefor the UCIP has no bearing what so ever on the temp reading in EvoScan.
Old Jun 13, 2007 | 12:54 PM
SuPeRNeT's Avatar
I did also clean my maf while the pipe was out too..
Old Jun 13, 2007 | 01:21 PM
4-BNGR's Avatar
Get some dryer hose and a heat shield, then report back
