Repercussions of big cams and stock IX turbo?
Old Jun 14, 2007 | 09:17 AM
incog6's Avatar
I'd like to know if performance gains and reliability will be adversely affected if I match GSC S2's with my stock IX turbo. This will only be temporary (6 mos max). Once I do the turbo upgrade (30R+), I know the gains will be there. My valvetrain will be upgraded along with the cams.
Old Jun 14, 2007 | 09:40 AM
juyanith's Avatar
If you're *certain* that you will upgrade in 6 months, I wouldn't worry about it. Just keep the tune conservative and I'm sure it would be fine. You can always ask GSC to make sure and if not, just wait the 6 months and do everything at once.
Old Jun 14, 2007 | 02:44 PM
southcalihds's Avatar
just do it.
Old Jun 14, 2007 | 04:01 PM
scheides's Avatar
EvoM Moderator
Do it and post the before/after dyno results! I'm sure they'll make good power and it'd be fine!
Old Jun 14, 2007 | 04:02 PM
kreionic's Avatar
I would still get the S1 unless you going atleast 35r
Old Jun 15, 2007 | 06:52 AM
incog6's Avatar
bump
Old Jun 18, 2007 | 10:57 PM
incog6's Avatar
bump
Old Jun 18, 2007 | 11:26 PM
EFIxMR's Avatar
The S2's aren't too bad on the stocker, however when you get a bigger turbo, the cam selection plays a big part in when it spools. With identical turbo setups, cam selection can spool up a turbo 500 rpm sooner. However, the cam that spooled up the turbo later made up to 30 more whp and held the rpm a lot longer.
