HELP: Anti Lock Light is on
Old Jun 23, 2003 | 07:10 AM
nastea's Avatar
Ok for some reason my anti lock light is on, i disconnected the battery to see if i reset the computer if it would work no luck....anyone got any suggestions before i go to mitsu?
Old Jun 23, 2003 | 08:40 AM
mayhem's Avatar
is your car stock?
Old Jun 23, 2003 | 10:30 AM
nastea's Avatar
yes
Old Jun 23, 2003 | 10:35 AM
Guru_Del's Avatar
take it to the dealer . or use a peice of electrical tape to cover the light
Old Jun 24, 2003 | 06:04 PM
nastea's Avatar
does anyone know what could have caused this?
Old Jun 25, 2003 | 06:16 AM
mayhem's Avatar
a sensor could have gone bad. or some other electrical problem. wouldmost likely be easy for the dealer to diagnose and troubleshoot.
Old Jun 25, 2003 | 06:24 AM
MitEv0's Avatar
i have the same problem and it was 2 of my abs sensor tthat got messed up so im waiting to get it fix
Old Jun 25, 2003 | 09:30 AM
mayhem's Avatar
the measured resistance for the ABS sensors should be 1.24-1.64 ohms.
Also check the rotor teeth to make sure they are in good condition.
Lastly check the G-sensor. Should be 2.4-2.6V. Manual says check with ignition on.
Old Dec 20, 2003 | 02:07 AM
nebolic's Avatar
i just have that problem occur i'm taking it to the dealer in the morning hope its a quick fix
Old Dec 20, 2003 | 02:57 AM
chrisitr's Avatar
My light came on and all I had to do was add some more brake fluid.
Old Dec 20, 2003 | 01:07 PM
BushBurninEvo's Avatar
mines come on when i turn off my engine and let the tt run. it doesn't come on when the car is on though.
Old Dec 20, 2003 | 01:42 PM
ReHeat's Avatar
Had a problem like this on my 3000GT, one of the ABS relay was shorted.
Old Dec 20, 2003 | 06:17 PM
nebolic's Avatar
mine was bad fuse, i have a horrible warranty story, i will post it in different forum
Old Dec 20, 2003 | 06:20 PM
YellowFever's Avatar
Pedro is this you??
Old Aug 4, 2005 | 07:56 PM
cliffsevo8's Avatar
mine also is on but when i break hard it goes away...but when i slow down it flashes and comes back
