Which intake has the most power gains?
Old Jun 17, 2007 | 07:42 PM
34Turbo's Avatar
^Well, actually thats kind of a good thing. That means its letting more stuff through, especially air
Old Jun 17, 2007 | 07:45 PM
hondafan's Avatar
i suppose. i would rather filter as much out as i can for a daily driver though. if it's a straiht race car, then i wouldn't mind.
Old Jun 17, 2007 | 07:49 PM
4WS Tuning's Avatar
that means it does the worst job at filtering air =-)
the difference between the best aftermarket filter and worst aftermarket filter is probably 2whp.. brand name im talking about.....
Cheers!
Old Jun 17, 2007 | 11:20 PM
red evo8's Avatar
if im correct they ran that test on the old hks material not the new 3 layered ones they are using now
Old Jun 18, 2007 | 12:02 AM
UCB's Avatar
UCB
KN+maf adapter ftw. I run a nice and small KN cone filter so it fits under the stock snorkel and box top. (good for stealth, good for cold air coming into the engine bay)
I run this, cost me $50, I put down identical numbers as someone running the bling arc box, with our other mods being very similar.
Old Jun 18, 2007 | 01:29 AM
WongFu's Avatar
I have the HKS RS but i do wish i used a diffrent one instead. Ok i might make more power then the rest but it is worth it since it doesnt filter as well? It does suck more air but guess what its sucking hot air from the motor too. i will be getting an induction enclosed one in the very near future
Old Jun 18, 2007 | 07:53 AM
hondafan's Avatar
i just like the apexi unit becuase in tests i saw it made good power, had the best filtration, and was a dry filter(no oil like K&N)so you don't get oil all over your MAF.
Old Jun 18, 2007 | 08:17 AM
nightwalker's Avatar
the HKS problem can be solved with a call to Outerwears. Search for it. ...and as far as intakes go, as long as you don't use a flimsy intake pipe, like a samco hose or something, then you won't have any problems. (They collapse under hard boost when the turbo starts sucking hard.)
