Boost Leak Test Question???
Old Jun 17, 2007 | 04:44 PM
hawaiian_evo's Avatar
Question Boost Leak Test Question???
I finally got around to doing my book leak test. And HOLY $H** i found two huge leaks from the licp. My licp was slightly damaged durring shipping https://www.evolutionm.net/forums/sh...d.php?t=267523. (strightened it out as much as possible)Tightened the clamps and fixed the leaks.
When I first pressurised the lines I could only reach 5 psi. As soon as the leaks were fixed i was able to pressurise up to 25 psi.(stopped at 25 because im only going to run 23-24psi)
Im doing the test from the turbo compressor with every thing hooked up other then the intake. As soon as i let off on the air it slowly leaks back down.
So my question is if the slow leak is normal or am i suppose to pump up to my psi goal and is it suppose to hold the 24 psi solid until i let the air out?
Like i said the leak is real slow hence the boost gauge drops slowly.
I did search this topic before asking and never came across an answer.
Thanks guys
Old Jun 17, 2007 | 04:48 PM
Thegame's Avatar
AS far as I know, you will leak a little through your MBC or stock BCS. And also, out of the valve cover.
Old Jun 17, 2007 | 04:52 PM
thanks for a quick reply Thegame.....
I spent hours trying to look and see if i could stop it...lol
Old Jun 17, 2007 | 07:03 PM
darqnez's Avatar
you should plug your little VC outlet with something and I never had any slow leaks at all when everything was working properly, if MBC leak is normal then clamp the lines off so your sure thats what the leak really is
Old Jun 18, 2007 | 02:35 AM
8UpUrV8's Avatar
if its not whining from any couplers or the throttle body, you should be good. air will leak out of other parts though as mentioned above
Old Jun 18, 2007 | 05:29 AM
o right ill try plugging the vc off. I have a Electronic bc so ill try plugg that off too.
And dgarnez your boost held up without leaking durring your testing?
Old Jun 19, 2007 | 03:01 AM
ItalianEvo's Avatar
Sorry if I enter in this thread, but it's IT... ;-)
I tested leaks closing the compressor intake with a cap...
is it normal that, in this way, I have a big leak ( no pressure built ) through the turbo oil discharge ?
