new gt35r setup with stock ecu
ok heres my new setup stock motor. Shearer gt 35r stock ecu , 1000cc injectors, sun hyperforce ignition stock ecu, smc alky kit, hks 272's. Is there anything im missing to run this turbo at 30+ psi and make over 500 hp, i heard of a maf translater is that necessary and cant i just remove the screen in the maf so it doesnt suck through.
im asuming all of them are running race gas or meth/alky, what about on pump, i cant access race gas without paying a fortune
Well, you wouldn't use a big turbo like this without using meth/alky or race gas. It's a big waste of money. You make low power with very late spool.
i see, maybe not a good option for me then as i dont want to have to build the block up, i know a few locals run gt35rs on build blocks on pump but like 30psi or over.
They are not running 30psi on straight pump gas on built block. That has nothing to do with it. You need the higher octane gas so you wont detonate the motor. I run about 22-23 psi on pump, I could run more boost but I would have to pull to much timing out.
