Turbine stops to blow at 5-6K rpm
Ladies and Gentlemen,
I have a problem
I have Evolution IX (it's not a problem yet, hold on...). Everything was fine untill 3-4 days ago I've noticed when driving on the 1-4 gear turbo stops to blow at 6K rpm and when driving on 5-6 gear - at 5K rpm. So full throttle at 4K rpm an we have nice 1.5 bar boost until the rpm limit. Then we have 0.5 bar (according to the Defi guages). Physically car stops to accelerate as well. Me and all of the mechanics are completely lost... What can it be?
Thanks!
-anton
I have a problem
I have Evolution IX (it's not a problem yet, hold on...). Everything was fine untill 3-4 days ago I've noticed when driving on the 1-4 gear turbo stops to blow at 6K rpm and when driving on 5-6 gear - at 5K rpm. So full throttle at 4K rpm an we have nice 1.5 bar boost until the rpm limit. Then we have 0.5 bar (according to the Defi guages). Physically car stops to accelerate as well. Me and all of the mechanics are completely lost... What can it be?Thanks!
-anton
well in fact a turbo can stall, but this is not whats happening here. its pretty obvious that u have some sort of boost leak in the system somewhere. check all the fittings as well as the stock solinoid. you should be able to hear it, i mean u are loosing 14.5 psi somewhere. listen for a loud hiss.
Actually it was cheap TRUST air filter. It sucked some water and changed internal structure once and forever... So after drying it stopped passing by air at high rpm when engine needs A LOT of the air. Replaced with the INJEN kit and everytjing is fine now.
Thanks a lot to the everybody
-anton
-anton
