oil light blinking?
Old Jun 20, 2007 | 08:50 AM
riksride's Avatar
oil light blinking?
I did a few track days recently and after I finished and came back to the pits, the oil light started blinking while I was idling. It was not on while I was driving and after I turned it off for a few minutes and then back on, it was fine. But it happened after each session. Oil level is full and nothing is leaking. Any one ever have this happen?
Old Jun 20, 2007 | 09:19 AM
sonicnofadz's Avatar
Search, this is a common problem. Did the problem go away after your engine cooled down? Your oil might have been so hot it thinned out and registered less oil pressure at idle. Also, what was your idle engine speed? Was it lower than usual?
Old Jun 20, 2007 | 09:52 AM
El.BlueEvo9's Avatar
It happens to mine when the idle rarely, but sometimes drop too low.
Old Jun 20, 2007 | 02:27 PM
spln*up's Avatar
that happend to friend of mine who is actually on here. everytime he was idling his oil light would blink. he had a faulty oil sender sensor, he bought a new one and problem solved.
Old Jun 20, 2007 | 02:39 PM
dafoe69's Avatar
I'm that friend. Turned out to be a faulty oil sensor. Replaced under warranty. It would flicker when I was idling but never while driving.
Old Jun 20, 2007 | 02:58 PM
riksride's Avatar
Thanks. I'll take it to the dealer since I've only 3k miles on it....
Old Jun 26, 2007 | 01:40 PM
Evo_Lution's Avatar
where does that sensor go?
Any clue how much it cost?
Old Jul 2, 2007 | 12:45 PM
ralliarv's Avatar
which warranty would this fall under because I have this same issue but I'm affraid mine might be up
