what can i expect?
Old Jun 21, 2007 | 04:46 PM
pitman's Avatar
what can i expect?
hi guys first post on this forum!
i have a 1997 evo4,built 2.0 litre engine standard head,bolt-ons as follows.gt3071r 3" downpipe and all the way through the exhaust,greddy intercooler kit, 4" intake pipe,battery relocated to boot,tial 38mm wastegate,stock manifolds,walbro in-tank fuel pump,720cc injectors,power fc.
i am mid way through collecting the above parts is there anything additional or diferent that people would reccomend?-i plan on having a car wich is street friendly wich can still be competitive on the strip and circuit.
what sort of #s should i expect tuned on 98 ron,i believe most of you are from the states and use mon measurement wich would equate to 93 pump gas i believe.
and what sort of times should i expect down the 1/4? its an rs model have very tight mechanical lsds and weighs in at 1200kgs(minimal sound deadening,manual windows and mirrors,air con removed) thanks in advance for any info/advice.
Old Jun 22, 2007 | 05:11 PM
pitman's Avatar
no one has any answers?
Old Jun 22, 2007 | 07:37 PM
IXmr321's Avatar
1/4 times are hard to estimate without knowing the amount of boost and/or the extreme of your tune(<~~~which should also be added to your list
Old Jun 23, 2007 | 09:30 PM
pitman's Avatar
will be getting dyno tuned using the power fc on 20 maybe 22 psi,360ish whp+ possible with these mods?
Old Jun 23, 2007 | 09:48 PM
GT35REVO8's Avatar
im not to sure about the evo 4,but if it reacts like the 8s then id say with that set up and pump gas 22psi i dont see why you cant crack low 400 high 300...ive seen evo 9 with minimal mods do 360..
but like i said i dont know much about the performance of the evo 4 motor..if its anything like the 8 then you should see high 3 low 4 on a good tune
Dannievo
Mar 15, 2017 02:14 PM
DutchEVOVIII
E85 / Ethanol
Mar 3, 2011 09:41 AM
4g634life
Oct 13, 2009 11:26 AM
Evo_4_Live
Jul 2, 2006 03:30 AM
lanceroz84
Apr 10, 2002 09:38 PM
