best way to hook up MBC
Old Jun 23, 2007 | 11:32 AM
laakness's Avatar
Originally Posted by Whoop_ass
do you have any boost issues
stable boost tapering, care to give some input
No issues at all. The majority of people gave me the same advice when I first was looking at doing this a couple years ago.
It also gave me a warm and fuzzy knowing my mbc was controlling the boost from the one place it originates
Old Jun 23, 2007 | 03:26 PM
sparky's Avatar
Cap off the port on the MAF pipe. No need to cap off the 2 ports on the BCS. Leave the electrical harness hooked up to the BCS.
Old Jun 23, 2007 | 08:22 PM
Whoop_ass's Avatar
OK installation done WG to Actuator
I will drive around like this and pull some logs and then i will try the other way
from BOV.
Easy to do now that everything is in place.
I will post my findings back here With MAP sensor logs
thanks for all the info
Old Jun 23, 2007 | 08:33 PM
whoang40's Avatar
installed mine by tapping to BOV line for pressure source. Boosting @20psi rock solid. Mine tapers to 18psi near redline.
Old Jun 23, 2007 | 11:26 PM
Whoop_ass's Avatar
Thanks for the info
Old Jun 24, 2007 | 01:26 AM
dsmfan95's Avatar
Ye i am using stock Outlet pipe!!
does the FP turbo not have a nipple on it dsmfan95?
is your boost stable on the BOV line any issues?
The FP outlet pipe doesn't have a nipple on it so I went with the BOV line for now. I don't have any problems with it as far as boost stability, but when I switch back to a stock Evo9 outlet pipe I will go back to using it at the boost source.
Old Jun 24, 2007 | 02:58 AM
hksevoix's Avatar
I have a hallman going to the bov and wastegate and I'm boosting 21 solid with no fluctuations all the way to redline, spools quicker too and pulls harder than the other way I had it coming off the turbo
Old Jun 24, 2007 | 07:06 AM
sparky's Avatar
OK installation done WG to Actuator....
What exactly do you mean by "WG to Actuator"? Please, explain.
Old Jun 24, 2007 | 07:15 AM
LoCo4's Avatar
I hooked up my MBC to the wastegate/turbo housing. Car has fast spoolup, will spike at 23 and hold 21-20 to redline. Every other car I have hooked up a MBC to I did the same install with the same results.
Old Jun 24, 2007 | 12:03 PM
Whoop_ass's Avatar
Sorry i meant housing and wastegate.....
i am a dumb *** sometimes... WG or Actuator same thing
thanks for picking it up
Old Jun 24, 2007 | 12:10 PM
cfdfireman1's Avatar
Not...
BOV line is not a pressure source once the throttle is closed.
Whoop_ass's Avatar
so you have tried both methods buddy?
if that is the case i am definenatly gonna go the other route.
installed the forge with the stiff spring and the dumb *** forge wont boost anything lower than 25-26 psi on it's lowest setting, had to remove stiff spring and install the lighter spring.
I boost to 22.75 (peak) and taper down to 18.2 psi t redline.
Old Jun 24, 2007 | 12:11 PM
wrong spring same thing for me you need the soft one.
Old Jun 24, 2007 | 12:18 PM
Whoop_ass's Avatar
yip......
damn man I could here the det
babyed it home till i changed the spring
Old Jun 24, 2007 | 02:29 PM
Planet Evo's Avatar
What does that have to do with anything?
