Car losing power in upper rpms
Old Jun 26, 2007 | 07:45 AM
diezilnj's Avatar
in first gear at around 6k the car starts to i guess sputter rapidly and loses power. if i keep on it through second it does it but not as bad once i hit 3rd turbo feels like it lags for a second and then hits really hard. im getting full boost. It is very unusual. I only have 17k on the car. i know this sounds unusual so i will try and take a video later. but if any1 has any idea what it could be id appreciate any input.
Old Jun 26, 2007 | 07:46 AM
Clutchdc5's Avatar
fuel cut? boost leak?, check your bov
Old Jun 26, 2007 | 07:47 AM
TeStUdO's Avatar
When you say sputter, do you mean the car is missing? What are your mods?
Old Jun 26, 2007 | 07:50 AM
diezilnj's Avatar
i have bushur tbe, and a cone filter. It honestly sounds like really quick backfires like its not burning all the fuel
Old Jun 26, 2007 | 07:52 AM
Clutchdc5's Avatar
are u tuned?
Old Jun 26, 2007 | 07:53 AM
diezilnj's Avatar
not yet
Old Jun 26, 2007 | 07:55 AM
diezilnj's Avatar
i thought tune could be an issue but i have had exhaust on for a few weeks now and this just started
Warrtalon's Avatar
1) Sputtering = plugs
2) 3rd gear delay = clutch slipping
3) Having a TBE and cone filter with no tune is completely asiIX
Old Jun 26, 2007 | 07:57 AM
TeStUdO's Avatar
Really quick sputtering is your plugs. If it feels like you hit a wall then that is fuel cut.
rcheung's Avatar
plugs
Old Jun 26, 2007 | 08:04 AM
diezilnj's Avatar
i had a feeling it was plugs. i looked around a littlebut not a whole lot should i get stock or are there better aftermarket plugs?
Old Jun 26, 2007 | 08:05 AM
Warrtalon's Avatar
Plugs are the least of your worries, dude...
Old Jun 26, 2007 | 08:06 AM
diezilnj's Avatar
im going to schedule an ivey tune also
Old Jun 26, 2007 | 08:07 AM
TeStUdO's Avatar
You have a IX so you cant switch to copper plugs, you are stuck with iridium. They are more expensive, but last longer than the coppers.
Your cone filter could be throwing off the MAF signal which is causing you to run lean. Get a tune ASAP.
Old Jun 26, 2007 | 08:09 AM
Warrtalon's Avatar
That also is not your main problem. Did you miss my 1-2-3 post above???
Plugs = $40?
Tune = $300-400?
Clutch = $1500
