ACT HDSS installed, 5th gear grind
Old Jun 26, 2007 | 05:25 PM
FastAzzEvo's Avatar
Ever since I had my act hdss installed, I frequently get some gear grind while going from 4th to 5th. I do not think it is my sychros because I just started having this issue after the clutch install.
If its just a matter of adjusting my clutch pedal how do i do it?
Do I adjust the pedal out towards me, or in towards the floorboard?
Thanks for the help.
Old Jun 26, 2007 | 05:38 PM
High_PSI's Avatar
Yeah adjust your pedal, the clucth isn't fully disengauging.
Old Jun 26, 2007 | 06:54 PM
FastAzzEvo's Avatar
do you know which way i go with it?
Its right now stock
I noticed right away that it engages almost at the top of the pedal travel.
Old Jun 28, 2007 | 03:39 AM
FastAzzEvo's Avatar
adjusted the pedal its still doing it sometimes? Not real bad though. I don't think its the synchro because this issue started right after clutch install, and suddenly.
I'm going to switch back to OEM fluid and see if that helps before I take it in to mitsu... I got royal purple in there now.
Old Jun 28, 2007 | 04:12 AM
Smike's Avatar
http://evomoto.com/tech_info.php?tec...2a40f07cf712bf
Try moving a bit higher.
