My FPGREEN is going in soon look at the goodies PICs
Laying on the floor
Brand new FP Green with 18psi wastegate spring
AMS LICP
Hallaman MBC
Ebay o2 Housing
EVO 8 install kit all ordered from Mitsubishiparts.net $86.xx shippped to my door
All new gaskets,(Manifold,o2 housing, and Turbo to Mani)
WOT Ported Stock mani tapped for EGT
I also had the o2 housing, and turbo ported by WOT
is they any type of sealant that goes on the gaskets?
AMS LICP
Hallaman MBC
Ebay o2 Housing
the mani is ported. the ports are enlarged to the the exhaust ports on a head, not the gasket.
?? You dont gasket match the exhaust port runners to the gasket. you do match the exhust mani to turbine housing, via the turbine housing gasket.
i applied the same porting technique used to port the parts on my car, which netted the power numbers below.
the numbers may not look very high, but they are on 91 octane with a evo8 16g.
the previous highest 16g turbo'd whp that have been dyno on @ yimis' was 336 while on 91 octane.
the mani is ported. I havent put the gasket up to it yet. what the estimated time for install.
FEBEVO what oulet pipe did you use? The stock evo 9 pipe or D.B pipe?
Just installed almost the exact same setup just today!
The evogreen was a quality piece. I had the manifold, 02 housing, and turbine all 2k deg coated also got the gasket set. I need to dial in the greddy ebc now because I boosted like 25psi! So you will probably want to turn down your boost controller a bit and work your way back up again.
