Weird Sound
Old Jun 27, 2007 | 06:55 PM
MRWINS's Avatar
Weird Sound
When i drive around in my 06 Evo MR I notice a sound coming from the front of the car everytime I let off the gas and the noise is the loudest in 4th gear. What could this noise be and is it something serious? I think it might be the transmission?
Old Jun 27, 2007 | 07:12 PM
jrsimon27's Avatar
be more specific is it a chaterring noise a clunck?
Old Jun 27, 2007 | 07:13 PM
MRWINS's Avatar
Its a rattle or some type of click. A few people said it might be my case or a diff
Old Jun 27, 2007 | 07:16 PM
jrsimon27's Avatar
i dont think that your transfer case is the issue cause they sound everytime not just because you lift off the throttle.
does the noise go away when you apply the gas back?
Old Jun 27, 2007 | 07:21 PM
MRWINS's Avatar
yes when i apply gas it goes away and when i let off it comes back also when u press the clutch all the way in it goes away and when u slowly left off u can hear it rattle or click it wasnt loud at first and now its getting somewhat louder
Old Jun 27, 2007 | 07:24 PM
jrsimon27's Avatar
i think its normal it might be your throw-out bearing what your hearing i have that same noise on my car since new i wouldnt worry much...
is your car stock? if yes then worry less and how many miles do you have on it?
Old Jun 27, 2007 | 07:26 PM
MRWINS's Avatar
i got 15k miles and i just got an ams exhaust intake and base flash i didnt notice it at first but i launched my car a few times and now i noticed this sound? Do u think my transmission might be going?
Old Jun 27, 2007 | 07:32 PM
jrsimon27's Avatar
not at all maybe you did put to much stress on your clutch components when you launched it. its your throw-out bearing dont worry just dont keep abusing of your clutch when you drag race
Old Jun 27, 2007 | 07:34 PM
MRWINS's Avatar
If i was to replace the bearing would it go away the sound? Also how possitive are you because i dont wanna keep driving on it and maybe mess something up
Old Jun 27, 2007 | 07:36 PM
jrsimon27's Avatar
you wont mess anything when replacing the throw-out bearing you must do a complete clutch install an iam pretty sure its your throw-out bearing
Old Jun 27, 2007 | 07:38 PM
MRWINS's Avatar
What type of clutch would u recommend? I live very close to AMS should i get their stage 1 clutch the Exedy
Old Jun 27, 2007 | 07:39 PM
jrsimon27's Avatar
wait till your oem clutch dies out then change it to the exedy stage 1 if your going for more power get the twin disc
Old Jun 27, 2007 | 07:47 PM
MRWINS's Avatar
I heard u need a built trans for the twin disc because it breaks the transfer case is that true?
Old Jun 27, 2007 | 07:49 PM
MRWINS's Avatar
Also wat if the noise gets even louder should i worry?
Old Jun 27, 2007 | 07:50 PM
jrsimon27's Avatar
not not true if you go a drag race and dont have enough wheel spin and you dump the clutch you will break it or if you put an oil thats not recomended and you will also break it
