Full-race's new toys
1) yes it will fit a GT4094R with no problem -- AC, full length radiator, power steering, etc.
2) the F1 turbos are oil and water cooled. They are available in ball bearing and non ball bearing, and with or without the bullet nut
3) The 67 is definitely not a GT wheel. I have seen the same compressor map as you (the garrett guys sent it to me) and its total BS. it says that its a BCI-18 but if you look closely it shows the exducer to be 81.5 mm, not the 84mm it actually measures out to be. I have no idea what that map is for, but its not the 67. The real compressor map is here:
are you sure? A T04E by definition is a T04E... not a BCI?
the reason the 50 trim kills every other T04E, is that its BIGGER!!
Any word on if the ball bearing system has been redesigned on the turbonetics though? There for a while they were using a "semi-floating" bearing system which seemed to fail the first time it say anything over like 20 PSI.
As for the T67, I'm just going off of what I've gotten from a few different sources that have reputations for knowing turbochargers quite well. One thing about the T67 map I have is that it says it is a "63/61 trim" or something to that effect. It has been quite a while since I've seen a T67 wheel or the complete map (the one I have that I can find I edited it down to use in a spreadsheet calculator), but is it by chance an extended tip wheel? Could that explain the discrepancy on the wheel diameters? I don't even know if Garrett has messed around with extended tip wheels though?
The map you posted looks roughly the same as the map I have as far as efficiency and shaft speeds. Garrett also has had a habit of randomly changing maps and wheel names/nomenclature with no real reasonable explanations as to how they all relate anyway. Garrett has so many wheels made with minor variations that it's really difficult to say what the wheels really are. Hell, the GT40 has had 6 blade and 7 blade wheels in it and the name never changed. Obviously they are not the same turbocharger though.
Isn't there a "GT37 76mm 50-trim BCI-18C" compressor wheel? I was under the impression that this wheel was what some of the smarter turbo builders where using in their "50-trim T3/T04E" turbochargers.
I know it seems like all of this is off topic, but picking the best turbo is the most important part of the setup and I'm interested in some of the choices Full-Race has made to find what they feel works the best. As always, feel free to answer or not answer as I'm just your regular turbo info junky, even when most likely I won't even use a lot of it.
Does the downpipe for the twin scroll GT35R kit combine the downpipe and o2 housing as one piece? Will there be an option to include an intake kit with these turbo kits? How much extra will it cost to include an intake kit?
There is no o2 housing as it's an external wastegate design. So the downpipe bolts up the the exhaust side of the turbo and that's it
. In actuality, for this setup it v-bands to the exhaust side.
So I am guessing FullRace only comes in an externally vented (open) wastegate exhaust setup, correct? I keep reading the great things full race is developing and they are starting to tug on my wallet, if Ted is on board that doesn't help any either
Max Power's picture is of a custom ATP Divided T3 housing, not the Full Race product. For GT30 and GT35 applications, Full Race uses a divided T3 as well, but it's a different housing, though it will look similar.
As for WG recirc, I'm sure you could get it done, but with 2 tubes to plumb back in, I'm sure it would be at least a little tricky.
It would be nice, some actuall results too becuase I am really interested in running the 4088 on a 2.0 instead of a 2.3 to see how well it would be for street and strip combo.
Scorke
Yeah, but if you ever had to take it apart, getting it all to line up again wouldn't be fun. Thank god it's all v-band connections, otherwise you'd be outta luck.
With the Above two GT35R's, which is better in terms of power and which in terms of spool? I am assuming that the left is the Garrett T4 and the right the Turbonetics F1-35R? How would a GT35R react with a twin scroll setup Vs. a traditonal manifold? I would love to have a 35R with this maniold and now MIVEC it would hopefully make even more of a difference.
A twinscroll setup would cause the GT35R to have better throttle response, more lowend/midrange power, faster spool, and allow you to use a larger and larger cam than you would normally think (of course that isnt necessary, but it is a benefit of twinscroll)
We offer the GT3071R and GT3076R as twinscroll AND single scroll. Garrett offers them as single scroll only, we purchase the single scroll turbos but put twinscroll housings on them
yes, which is a big reason why the stock turbo is so responsive and works so well
i wont be able to get back to this thread until friday, thanks for the discussion
