forge mbc problem
Old Jul 1, 2007 | 02:30 PM
MRevolutionRed's Avatar
forge mbc problem
well i got my forge mbc a while ago but havent put it in till now and i was hearing from eveyone at my meets that if you run the spring that come in the mbc from the factory your boost will taper more. so they said put the other spring in that comes with the mbc, so i did.and they also told me to keep compressing the spring with your fingers for a while before you put it in so it wasnt so stiff, so i did that as well. now i have the mbc turned all the way down and i am hitting 24+psi. any advice would be great. thanks guys.
-Jeff
Old Jul 1, 2007 | 02:37 PM
JordanS4's Avatar
what is the problem again? the stiff spring isn't for taper, it is for high boost. if you want less than 24 psi, put the soft spring back in. also, how are you determining 24 psi (what gear and what RPM are you going WOT)?
Old Jul 1, 2007 | 03:14 PM
Evo_Jay's Avatar
I have gotten rid of some taper using the stiff spring on the soft. Read this post I made.
https://www.evolutionm.net/forums/sh...d.php?t=259636
Old Jul 1, 2007 | 03:57 PM
cfdfireman1's Avatar
AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH put the soft spring in?
sternevo8
Sep 1, 2012 12:22 PM
Evo_Jay
26
May 27, 2007 03:24 PM
AfireINSIDE
Feb 17, 2007 05:35 PM
QuickEvo
15
Oct 26, 2005 03:38 PM
