Intercooler lines blowing off!
One of my intercooler lines blew off about a month ago and today when i put on a downpipe and test pipe a different one has blown off twice in a few hours how can i fix that i am running stock boost
i would upgrade the clamps to t-bolt or forge clamps i havent been able to pop any forge clamps yet but i have broken some t-bolt clamps of course well above stock boost or get an intercooler piping kit.
invest in t-bolts......go to the "how-to" section for a write up on installing t-bolts if you dont know what sizes to get, etc.
It should be one of the first things anyone should do when they start modding the car, but is always overlooked. The clamp a lot harder and also will help minimize boost leaks.
The stock worm clamps are p.o.s
T-bolts are great but the stock ones will work for stock boost without a problem as long as they are positioned correctly and tightended like Warrtalon said with a rachet instead of just a screwdriver. The placement is most important though, make sure its placed right after the lip on the IC pipes! I am running 30psi+ on some stock clamps still. I only have T-bolt clamps on the LICP.
