Turbo Orgy
those are some crazy lookin snails. That one is ginormous, looks like it belongs on a BB V8.
I have a question for you on the Full Blown pump assy. Do you run both pumps all the time or click one on at preset boost? I assume you don't drive the car much on the street and such, but do you feel the rich spike in the car that the pump coming on generates?
I tried to run both pumps all the time tonite, and it baselines pressure at 63psi with the aeromotive regulator all the way down, lol.
Scorke
the fuel pressure with no vacuum line connected is supposed to be 42 psi. However with both pumps running(I have them hard wired with a relay straight from battery, with stock feed wire triggering the relay) I am seeing 63psi.
I am running this FPR(http://store.summitracing.com/partde...5&autoview=sku).
I have decided to just let the AEM trigger another relay, which I'm going to wire up this week before my tune on Fri at TurboTrix.
Scorke
TTR says they use an inline that is on all the time, and let the stock setup feed the intank, and it works for them, so I don't see why it would not work for you. Try it and let us know
, that's what i am getting on Monday.
