got my green after 3 months, pics inside.
Old Jul 9, 2007 | 08:09 PM
Dr. SS's Avatar
Originally Posted by gsnt
Is that turbo from FP?
yeah its a green. 20g-9-5LT
Old Jul 9, 2007 | 08:25 PM
04AWDTURBOEVO's Avatar
Originally Posted by Dr. SS
ordered 4/9/07, received 7/9/07
question for green owners: my WGA is not the typical goldish looking. its grey and it feels coated. is this the 18 psi wga? because i didnt want the 18 psi wga as im not running alky/race gas or high boost.. can anyone confirm from the pics?
That WGA is the regular IX actuator.
The Hi-PSI actuator has 2 bolts on the bottom of it, 1 on each side of the rod.
You will have to cut the Turbo discharge pipe (the chromed one), or the LICP, which ever you choose. I had to cut mine. Too long.
You must have sended your Turbo in for conversion. The brand new 20G-Lt's come with the serial numbers erased and with the single flapper hotside.
The Ebay intercooler will work good with the 20G-LT. It is the same one I have been using for 2 years with great results.
If money is not an issue, a better Intercooler is allways nicer, .
Good luck with your set-up. You will have alot of fun.
Dr. SS's Avatar
Originally Posted by High_PSI
I believe that if you hook up a Buschur product to an Ebay product, they will both spontaniously combust. The Buschur product would simply rather kill istelf then be subject to that combination
good thing its not a buschur product.
Old Jul 9, 2007 | 08:27 PM
Dr. SS's Avatar
yeah it was on the exchange program. i havent sent in my core yet though. this is before they shut it down. its a double flapper but still a 10.5, but ur right all the new ones are single flappers.
how much did u have to cut the discharge pipe by?
Old Jul 9, 2007 | 08:38 PM
4G63's Avatar
I believe that if you hook up a Buschur product to an Ebay product, they will both spontaniously combust. The Buschur product would simply rather kill itself then be subject to that combination
Old Jul 9, 2007 | 08:41 PM
alan678's Avatar
That turbo outlet and LICP will NOT work together...you need to get an OEM outlet pipe for your install...
I wish they were coating the the hotside when i got my turbo
Old Jul 9, 2007 | 08:53 PM
Dr. SS's Avatar
well its supposedly a IX oem outlet pipe, it came with the VIII to IX install kit.
can i use the discharge pipe off of my EVO VIII turbo? its shorter i think... i still have it....
good to know before the install happens this weekend...
Old Jul 9, 2007 | 08:54 PM
The turbo pipe will work.
Just have to cut it. Make sure you meassure before any cutting.
And make sure the silicone couplers fit each pipe end before any work.
Here is a pic of the pipe, you can see how much I cut off. I saved the pic for a day like this, , and a pic of how the Hi-PSI actuator looks like.
Attached Thumbnails got my green after 3 months, pics inside.-cut-pipe.jpg   got my green after 3 months, pics inside.-wgahipsi.jpg
Old Jul 9, 2007 | 08:57 PM
No. If you do you will have a short circuit problem with your engine starter. There is a thread on this, .
RazorLab's Avatar
That is not a evo 9 oem outlet pipe. The oem pipe is black, has a vac nipple on it and is much much shorter. The one you have looks like a Buschur outlet.
If you do cut it to work I would get the end beaded again as it can pop off without it.
Where did you get the VIII to IX kit?
Also, you cannot use the evo 8 outlet on a 9 compressor housing.
Old Jul 9, 2007 | 08:58 PM
Dr. SS's Avatar
Here is a pic of the pipe, and a pic of how the Hi-PSI actuator looks like.
oh wow, u gotta cut quite a bit. was that discharge pipe a oem IX or a oem VIII dc pipe?
guess ill pick up some new cutting wheels for the dremel...
Old Jul 9, 2007 | 08:59 PM
Dr. SS's Avatar
oh ok. can i pick this up at the mitsu parts counter? anyone have the part number to the oem IX discharge pipe? TIA.
i got the adaptor kit from forced performance. I guess they sourced BR for it...
Old Jul 9, 2007 | 09:00 PM
Soon2BEVO's Avatar
Thats the best thing Ive read all week. Thanks Matt
Old Jul 9, 2007 | 09:07 PM
alan678's Avatar
Sure it will work with some cutting...you can make anything work with custom fabrication...but its def not a 'bolt on" application as most would like...
Old Jul 9, 2007 | 09:12 PM
RazorLab's Avatar
Looks like you have to specify what pipe you want, maybe you can return it and get the OEM one?
http://store.forcedperformance.net/m...de=Lancer-Misc
Originally Posted by FP site
This product is designed to ease installation of your FP Evo Green Turbo onto your Lancer Evolution VIII and can be had in either OEM pipe which fits the stock IC pipe locations or the Polished SS Race pipe style which is compatible with popular aftermarket FMIC kits such as Buschur and others. The kit comes with the following items:
Evo 9 Compressor Outlet Pipe (Race pipe or OEM pipe)
Evo 9 Oil Feed Line
Evo 9 Water Lines
Copper Crush washers for oil and water lines
Oil Drain tube gaskets
Turbine Housing Inlet gasket
Turbine Housing Outlet gasket
Compressor Housing to Outlet Pipe gasket
