got my green after 3 months, pics inside.
Old Jul 9, 2007 | 09:18 PM
  #31
04AWDTURBOEVO's Avatar
Originally Posted by alan678
Sure it will work with some cutting...you can make anything work with custom fabrication...but its def not a 'bolt on" application as most would like...
95 percent of the time, some minor adjustments are needed to parts such as brackets, pipes, flanges, and pipes. This is a minor adjustment. All you got to do is bolt the pipe on and then cut a piece off. It is not a custom fabrication job. The Buschur pipe was designed for his lower intercooler pipe and intercooler. That is why is longer than stock.
It took me 15 minutes to cut this pipe.
I cut'd it, smooth'd the ends, polished and it has worked fine to date.
Also, it looked to me as if this pipe is actually of bigger diameter than the stock discharge pipe. I would have to check.
The other solution you guys allready have mentioned. Buy a IX discharge pipe.
CDrinkH2O
Nov 11, 2013 12:41 PM
snazzyseth
Jan 17, 2011 05:50 PM
Phalse
41
Aug 17, 2008 10:14 AM
recompile
69
May 11, 2008 06:15 PM
recompile
12
Mar 31, 2008 07:42 AM
