Which Turbo?
Old Jul 10, 2007 | 11:35 AM
TeStUdO's Avatar
Originally Posted by richysevo8
The Evo green works the 20LT doesnt
They are the same turbo genius. The Evo Green is made and sold by FP and the 20gLT is made by FP and sold by Buschur.
Old Jul 11, 2007 | 05:03 AM
V8eatr's Avatar
Talked to CarV2 yesterday after dropping my car off and im going with the FP Green! Now my next question is what size injectors do you think i should go with? I have a turboXS tune currently and am getting an AMS tune after the turbo. I dont want anything to over the top but just enough.
Old Jul 11, 2007 | 05:13 AM
TeStUdO's Avatar
680's will be enough.
Old Jul 11, 2007 | 05:22 AM
FedEvo8's Avatar
Thumbs up
The 20G is a standard Evo 9 turbo. The 20G-LT has a bigger compressor/turbine wheel LT = Large Turbine. It flows way better than stock! I'm loving my 20G-LT!
Old Jul 11, 2007 | 05:30 AM
TeStUdO's Avatar
The 16G is a standard Evo IX turbo.
The 20g is a 20g wheel stuffed in an VIII or IX housing.
Old Jul 12, 2007 | 05:34 AM
V8eatr's Avatar
One last question...im ordering the FP Green today. Would you guys suggest getting it ported and the turbine housing coated or should i not worry about it? Also whats the difference between the 9.8cm2 and 10.5cm2 single flopper housings. I will stay around 20/21psi if it helps.
Old Jul 12, 2007 | 05:39 AM
Soon2BEVO's Avatar
Definitely get it ported, coating is a toss up. I think its a good idea and have it done.
Secondly, 10.5 is going to make more power. Get it. The 9.8cm housing is like your stock 03-04 turbine housing. You dont need to stay around 21psi with this turbo. Id run at least 23psi on it or I would not bother buying it.
Old Jul 12, 2007 | 05:40 AM
V8eatr's Avatar
Sounds good...thanks man i appreciate it
Old Jul 12, 2007 | 05:53 AM
Soon2BEVO's Avatar
No prob!
Old Jul 12, 2007 | 06:12 AM
El.BlueEvo9's Avatar
LOL
Old Jul 23, 2007 | 09:08 PM
EvoTio's Avatar
Props to TeStUdO for straightening out the misinformation from some of these newbies. Please, if you don't know what you're talking about please don't post.
