2.4 Blocks and measurements
Old Oct 7, 2007 | 01:40 PM
  #46
sonicnofadz's Avatar
Originally Posted by homemade wrx
one more wrench to toss your direction is what will you use for your timing belt?
I know where to get/do everything else custom
its the reason my current build is staying stock deck height.
Lol I was thinking the same thing. A custom timing belt is not easy to come by. Depending how long the extension is, you might be able to use the 4g64 timing belt and use adjustable cam gears.
BTW: Feldguy, how is it possible to build a 2.6L using a 4G64 block?
Old Oct 8, 2007 | 08:54 AM
  #47
homemade wrx's Avatar
well, ams seems to have good luck with there sleeving which also allows a bigger bore
That brings several perks...mostly from the heads point of view but of course added displacement.
as for the 2.6L question...106mm stroke and a little bore...if you sleeve you can get a little more bore.
R/TErnie
80
Jan 7, 2021 02:46 PM
trinydex
35
Sep 6, 2015 08:11 AM
14968221
Jul 20, 2015 03:53 PM
TakaseEVOIXSE
203
Jun 3, 2012 01:30 AM
bigleadfoot
Sep 18, 2008 08:20 AM
