10 psi again?????????????
Old Jul 17, 2007 | 10:17 PM
jeffreyinigo's Avatar
Hey guys I am back to 10 psi. I hooked up the mbc and know for a fact i did it right because i turned it up and it went to 17psi at one point because i just kept on turning it. I started slowly of course. then after that i turned it up again and it went back down to 10psi. it never went back up. i replaced the spring to the harder oneturned it up all the way and still at 10psi. what can it be??????
Old Jul 17, 2007 | 10:28 PM
evo150's Avatar
inspect your vaccum lines. did you ziptie all the ends?
Old Jul 17, 2007 | 11:56 PM
ok. ill chk those and i didnt ziptie those ends. anything else i should check for???
Old Jul 18, 2007 | 06:21 AM
Warrtalon's Avatar
Check all the MBC connections and IC connections. It sounds like something popped off.
You have to secure each connection in the boost system - you can't just slide the hoses over the nipples.
slowonder
Aug 19, 2013 07:06 PM
awdordie
18
May 6, 2012 07:48 AM
Rayne
44
Mar 20, 2012 08:05 AM
EVO IXMR
13
May 21, 2011 05:34 PM
drewblueeye
Aug 30, 2007 07:33 AM
