catless Helix HFC
Old Jul 21, 2007 | 11:51 AM
Positron's Avatar
catless Helix HFC
123
Old Jul 21, 2007 | 12:04 PM
rcheung's Avatar
Well if you dont mind running a testpipe its fine.
Old Jul 21, 2007 | 12:43 PM
Positron's Avatar
Running it as a testpipe is no problem with me. I removed the substrate brick. Its nice and smooth inside like a testpipe.
Its just the "thermal barrier heat-shield" in the Helix HFC. Not sure if that will cause any problems.
"The Helix Hi-Flow cats are the optimal system for the performance minded EVO owner. This particular high-flow cat incorporates a 200 cell Metal-Substrate high-flow catalytic converter and thermal barrier heat-shield. The thermal barrier heat-shield assists in rapid warm-up of the cat for maximum efficiency and helps to keep exhaust gas velocities high.. Piping diameter is 3 inches and includes all neccessary hardware for trouble free installation. "
Old Jul 21, 2007 | 06:35 PM
pulley1fan's Avatar
You should be ok.. dont worry about it
Old Jul 22, 2007 | 10:35 AM
rcheung's Avatar
You high end is probably felling more peppy now.
