Please help! The pursuit of better boost control for a 16G.
Old Jul 24, 2007 | 12:34 PM
Luis@TTP's Avatar
go with a forge wastegate acctuator with a red spring it will help out
Old Jul 24, 2007 | 02:07 PM
Mad_SB's Avatar
Originally Posted by razorlab
Then you most likely had your closed loop load targets with offset set wrong or your pill size or lack or pill wrong. Did the 100% stock BCS system overboost with the 100% bone stock ecu map?
.... Yeah, his car was acting very strange when we first tried to tune it with the stock bcs. I've done plenty of bcds tuning on my own and several customer cars, and his was just acting wack. We were short on time so Noize decided to slap in a manual.
I've had great results with the GM solenoid and ecu control, still need to do a little fine tuning but it responds way better than the stock solenoid.
We are going to get him on the gm next time he comes down and get it dialed in to suit his boost preferences.
Old Jul 24, 2007 | 04:22 PM
sonicnofadz's Avatar
I'm using the stock 03 turbo with stock 9.8 hotside, and a plain jane hallman MBC. I hit 24 psi at 3000 psi and it holds all the way until redline.
Old Jul 24, 2007 | 04:25 PM
RazorLab's Avatar
Got an actual log and not eyeballing the (usually inaccurate) gauge?
Old Jul 24, 2007 | 04:42 PM
My gauge isn't inaccurate. I've tested it with two different hand pumps and its dead on. To my knowledge there isn't any way to log boost without the JDM map sensor (which I don't have)?
Old Jul 24, 2007 | 05:35 PM
accident's Avatar
the gm solenoid is nice and you can pretty much make the boost flat or taper how you want but it is frustrating to tune (I'm still working on mine )
ed
Old Jul 25, 2007 | 05:44 AM
scheides's Avatar
EvoM Moderator
Originally Posted by ASE_Tech@TTP
have you tried a forge waste gate actuator with a red spring 24-25psi in it with the propper amount of preload you can hold 21 psi i hold 23 -24 psi at 8k
Do you guys have any hard evidence to back this up? I really want to see logged boost curves and before/after dyno comparison on this one, as everyone and their mom swears that these things normally don't make much difference...but I haven't seen any specific info on the ones w/ the red spring.
Old Jul 25, 2007 | 06:22 AM
dsmfan95's Avatar
Originally Posted by mudduck
I'd recommend doing a search on here for TURBODAWG from NC. He sells a manual with specific settings for RPM-controlled boost - used with an HKS EVC 6, and has videos showing his car holding like 23psi straight past 8500rpm on a stock turbo... Also, he has quoted dyno gains of like 20-30 top-end whp over a traditional mbc....
This is what I will do one day when I can afford that EBC...
I'm using the HKS EVC6 as recommended by TURBODAWG. I was holding 22psi on the stock turbo to 8000rpms with the stock airbox. After changing to an open filter, I was able to hold 24psi.
Old Jul 26, 2007 | 05:46 AM
scheides's Avatar
EvoM Moderator
bump! TTP do you have any hard evidence to back up this forge wga/red spring combo?
Old Aug 7, 2007 | 10:29 AM
scheides's Avatar
EvoM Moderator
bump again! TTP where are you to back up these claims?
Old Aug 7, 2007 | 10:47 AM
Luis@TTP's Avatar
yes i have my own logs showing boost be held at 24 21 psi at 8000 and bounceing of the revlimiter no dyno sheets thhough.
Old Aug 7, 2007 | 11:07 AM
scheides's Avatar
EvoM Moderator
Cool, can you post them?
Old Aug 7, 2007 | 12:37 PM
nj1266's Avatar
As Razorlab mentioned ECU boost control is fantastic. I have set up my car with a #65 pill and got great results. The car can hold boost @ 20-21 all the way to redline or I can taper the boost to 19 by redline.
This table show boost holding to 20-21 by redline
And this table tapers the boost to 19 psi by redline
Each one of these tables is a compilation of 3-4 logs. You can set-up your boost anyway you wish with ECU boost control. You can taper it by redline or hold it @ 21 all the way to redline. I have settled on the taper since the stock turbo will be outside its effeciency range and no power to be had.
Old Aug 7, 2007 | 01:16 PM
scheides's Avatar
EvoM Moderator
With a simple MBC and my current mods my car holds 20psi at redline no problem. I'm interested in some hard data on holding 23-24psi at 7k rpms.
Old Aug 7, 2007 | 01:59 PM
nj1266's Avatar
Do you have logged data showing 20 psi @ redline? Or are you simply relying on the boost gauge?
