My IX won't start!
My IX won't start!
i've had the front of the car on jack stands for about 2 weeks and the last week i pulled the upper ic pipe, battery and ecu out. i needed to start it today and my friend was over with his ix so i threw in his ecu and cranked, nothing. tried again for maybe 10 secs nothing...... only thing i could guess was his ecu wont work in my car or sitting for 2 weeks with the front up in the air drained the fuel to the back..... how much cranking though should it take to get the fuel there. little confused any answers?
if im understanding your post correctly... to took the ECU out of your friends car and put it in yours... if in fact this is what you did...this would not work because the immoblizer code of your buddies ECU would not match your key's code...and you couldnt use his key b/c your ignition would not unlock with his key.
sweet sounds like we got an answer. my ecu is at bucshur right now and i was going to install a walbro. it says in the instructions to run the car with the fuel plug off till it died so...... anyway it didnt need to be ran i installed it anyway no problem.
