front wheels only spinning
Old Jul 30, 2007 | 01:26 PM
red2003evo8's Avatar
i was wondering if anyone on here has ever seen this problem or have heard of it. i dont know if it would be my center diff in the tranny not sending the power to the tcase to the back wheels or if it would be my my t case. i dont think it is my tcase cuz like 2000 miles ago i put a stage 2 shep tcase in it. so any help would greatly be appreciated.
Old Jul 30, 2007 | 01:32 PM
BenjyJ's Avatar
ummm.
are you just losing a bit of traction for a second??
cuz that would be pretty normal if youre launching or something i'd think.
if youre driving a full blown front wheel drive car, i think itd be pretty obvious that that's not right/normal.
Old Jul 30, 2007 | 01:33 PM
EVO MR's Avatar
is your e brake all the way down... I have heard a rumor that states if the ebrake is up it disengages the center diff.
Old Jul 30, 2007 | 01:36 PM
no i mean ive put it on a lift and the fornt wheels are the onlye ones spinning, the back ones wont move.
Old Jul 30, 2007 | 01:44 PM
chrisw's Avatar
is the rear drive shaft turning?
Old Jul 30, 2007 | 02:06 PM
nope just the front axles and the wheels.
Old Jul 30, 2007 | 02:19 PM
4WS Tuning's Avatar
when i launch i get a lot more front wheel spin than back...
if you pm me i'll send you a link with a vid of me launching and you can see it..
completely normal, i just drop the front tire pressure a bit more than the back to hook up.
Cheers!
Old Jul 30, 2007 | 03:36 PM
i dont think yall are understanding me. i can put it on a lift in mid air and go through all 5 gears and the rear tires will never move. i think it is the center diff in the tranny but i dont know.
Old Jul 30, 2007 | 03:40 PM
chrisw's Avatar
well there is your problem... try taking a closer look at the transfer case. I'll bet you find problems in there.
good luck!
Old Jul 30, 2007 | 04:40 PM
nightwalker's Avatar
are you hearing anything from the center diff? was there something weird about the car that prompted you to put the car on the lift and drive it? ...because a car driven on a lift is very different from a car that's on the ground loaded up. The differentials act very different without load on them. You may be getting all worked up for nothing.
Old Jul 30, 2007 | 05:04 PM
yes i put it on a lift because i was driving my car and i heard a loud grinding sound when i down shifted and then it turned in to a clanking sound. well i put it on the lift and put it in gear and only the front wheels would spin and it wasnt making that clanking sound or anything. i know there is something wrong with it cuz ive had it on a lift before and put it in gear to see if my rims would clear along time ago and all four tires spun. and ive drove it and it doesnt drive like an evo should it drives like a fwd car.
Old Jul 30, 2007 | 05:06 PM
Bom's Evo's Avatar
you put front LSD in your 2003 evo?
Old Jul 30, 2007 | 05:12 PM
bandilero's Avatar
try to get a mechanic to help you with this. it could be anything from your rear diff to t-case
Old Jul 30, 2007 | 05:15 PM
bandilero's Avatar
i had a similar problem on my 03 and the drive shaft had to be replaced
Old Oct 13, 2007 | 12:31 PM
rocar@onvol.net's Avatar
What happens if you lock(weld) the centre diff in the tranny?
EvilDSM97
Jul 16, 2016 06:10 PM
Don Q
May 10, 2012 08:11 PM
Davethewave
Jan 6, 2009 07:14 PM
03redtype-s
15
Oct 16, 2007 03:31 PM
Chris@nolimitmotors
Dec 8, 2005 06:23 AM
